Old 11-07-2010, 05:48 PM
Renato Lima Renato Lima is offline
Detect a double click on a gui slider
Is it possible to detect a double click on a slider?
Old 11-07-2010, 07:10 PM
Please, benjamin. Enlighten me with your knowledge.
Old 11-08-2010, 04:49 PM
A silder event is only generated when the slider changes position. If you doubleclick on the same spot no event will be generated for the second click so you can't tell it occurred.
Old 11-09-2010, 03:19 PM
What if I try to check if mouse is over a slider after doubleclick?
Old 11-09-2010, 03:23 PM
This is how I solved my problem:
def onDoubleClick(e):
if e.button == viz.MOUSEBUTTON_LEFT: print 'Left button double clicked'
print Gui["YRBox_Speed"].dragging()
viz.callback(viz.DOUBLE_CLICK_EVENT,onDoubleClick)
#viz.callback(viz.SLIDER_EVENT,onSlider)
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 12:22 PM
help with slider code yak Vizard 2 07-20-2009 01:12 PM
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 09:05 PM
Blending/Fading 5 Textures with a Slider south_bank Vizard 2 05-15-2008 08:59 AM
On click Sound Play Problems Robbos Vizard 1 02-28-2008 03:02 PM
