Old 10-29-2010, 12:35 AM
meck meck is offline
animationpath
Hello all.
Is it possible to make two or more animation paths link to one object?
Thanks for your help.
Old 10-29-2010, 10:20 AM
Yes, you can move an object from one path to another by disabling the link to one and enabling the link on the other.
Old 10-31-2010, 11:45 PM
Hello.
How should it be done to begin the second animation path after the end of the first animation path?
Please tell me an example code.
Old 11-04-2010, 05:43 PM
You could check the position of the object linked to the animation path every frame. Once it's within a close range of the endpoint you can disable the first path link, enable the second path link, and then play the second path.
