Old 10-29-2010, 10:03 AM
EARMC EARMC is offline
Single Marker Data
I'm trying to track the motion of a ball, and would love to be able to paint the ball with reflective paint/cover it with marker tape and make it into one marker. Is there a way to track the position of the single marker and stream that data to vizard? I don't think it is feasible to put 3 markers on the ball so that I can make it an object...
Thanks!
Old 11-01-2010, 06:03 PM
It's not clear to me what you are trying to achieve. If you just need position data then one PPT marker is sufficient. If you need position and orientation data then the best option would be to add an orientation sensor, like an Intersense, as well.
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
marker id plug-in Vkathrynr Precision Position Tracker (PPT) 1 09-25-2009 04:31 PM
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 06:17 PM
