Old 08-24-2010, 01:58 PM
mkmatlock mkmatlock is offline
chain mesh collisions
Hi!
I have a chain link ( a plane, with transparent texturing ). I am trying to make a complete chain out of links programatically.
This works fine, however, when I try to simulate the chain hanging and swaying (by attaching one end to a joint, and setting "Collide Mesh"), vizard locks up completely.
I don't want the chain to bend at each link, just at the point from which it is hanging (the chain is supposed to be under high load, so lots of flopping around would be unrealistic).
I assume vizard locks up because the chainlink meshes technically intersect one another. Is there a way to apply gravity to an object WITHOUT giving it a collide<Type>() command?
Code follows:
import math
# distance is meters
# mass is in kilograms
# gravity is 9.81 m/s
viz.phys.enable()
viz.phys.setGravity([0, -9.81, 0])
viz.startlayer(viz.LINE_STRIP)
viz.vertexcolor([1,1,1])
viz.vertex([0,0,0])
viz.vertex([0,0,4])
viz.endlayer()
def create_axes(length, parent):
	viz.vertexcolor([0,0,1])
	viz.vertex([0,0,0])
	viz.vertex([0,0,length])
	viz.vertexcolor([0,1,0])
	viz.vertex([0,0,0])
	viz.vertex([0,length,0])
	viz.vertexcolor([1,0,0])
	viz.vertex([0,0,0])
	viz.vertex([length,0,0])
	object = viz.endlayer()
	if(parent != 0):
		object.parent(parent)
	return object
def create_chain(length):
	link_count = length / 0.1 + 1
	a = 0
	head = 0
	plink = 0
	while(a < link_count):
		if(head == 0):
			head = viz.add('data\\chainlinks.IVE')
			head.setScale([0.0142,0.0142,0.0142])
			head.collideMesh()
			plink = head
			link = viz.add('data\\chainlinks.IVE')
			link.collideMesh()
			link.parent(plink)
			link.setPosition([0,0,7])
			link.setEuler([0,0,90])
			plink = link
		a=a+1
	return head
chain = create_chain(4.0)
#chain.setEuler([0,90,0])
chain.setPosition([0,4,0])
joint = viz.phys.addBallJoint(chain, None, pos = [0,4,0])
create_axes(100, chain)
create_axes(1, 0)
viz.MainView.setPosition([5,2,5])
viz.MainView.lookat([0,2,0])
Old 08-31-2010, 01:44 PM
Can you attach the .ive file used for this script or upload to http://www.worldviz.com/support/upload.html?
Head mesh indirection Enlil Vizard 2 07-08-2010 09:11 AM
Avatar bones show through Mesh. vEsotu Vizard 3 11-03-2008 12:38 PM
Multiple Mesh Avatar Texturing v-jbinney Vizard 6 11-13-2007 12:00 PM
LOD per individual mesh?? krimble Vizard 4 01-15-2007 05:46 AM
changing the texture of an avatars shirt/body bailenson Vizard 19 05-04-2006 11:00 AM
