Old 08-17-2010, 04:43 AM
TarkaDahl TarkaDahl is offline
Texbox deselecting
Hi All,
Im using a couple of textboxes in my code. The problem is that if you have one textbox selected you have to double click on another textbox/button to selected/press it. The first click deselecting the first textbox.
The people in my office are finding it really anoying, is there anything that i can do to change this. I am putting in some sort of tab ordering, but they want to single click between textboxes and buttons.
Any help would be good.
Old 08-18-2010, 01:28 PM
When a textbox loses focus you could check to see if the mouse is over another textbox and make it active:
import vizdlg
panel = vizdlg.Panel(align=vizdlg.ALIGN_CENTER)
panel.addItem(viz.addText('Textbox1'))
textbox1 = panel.addItem(viz.addTextbox())
panel.addItem(viz.addText('Textbox2'))
textbox2 = panel.addItem(viz.addTextbox())
viz.link(viz.CenterCenter,panel)
def updateFocus():
	object = viz.pick(0,viz.SCREEN)
	if object == textbox1:
		textbox1.setFocus(viz.ON)
	elif object == textbox2:
		textbox2.setFocus(viz.ON)
vizact.onbuttonup(textbox1,updateFocus)
vizact.onbuttonup(textbox2,updateFocus)
Old 08-18-2010, 05:23 PM
Hi Jeff,
Ill try that first thing in the morning.
Old 08-26-2011, 03:02 PM
rage1 rage1 is offline
textbox deselecting and radiobuttons
I'm creating a GUI and I had the same problem. Your approach worked quite well for the textboxes, but what do I have to do with radiobuttons after the textboxes?
Between the textboxes and the buttons is an invisible radiobutton, so none of them is selected. Could you give me a hint how to solve that case? Couldn't find a workaround yet..
Thanks, Rachel
