Old 07-27-2010, 03:07 AM
cyclonseye cyclonseye is offline
Jumping and Noise in head tracking
Hello
My name is Hyeob Choi, and I am using Vizard and EVarT for head tracking
and making vision correspond to head track information.
I made a body in EVarT, and Vizard reads the body's information(6 DOF).
Then, I linked view point and the body, and I could make head tracking vision.
However, there is a problem.
The vision periodically jump.
It is unrelated to EVarT. It also jumps when EVarT is not turned on.
Why does it happen?
Another question is about noise.
There is some noise in EVarT information.
I want to ignore it, although head tracking sensibility decreases.
How can I do it?
I would really appreciate your help.
Thanks.
Old 07-27-2010, 01:49 PM
Is the framerate in Vizard dropping when you notice this jumping? You can check that by pressing F4 when your script is running?
Old 07-27-2010, 08:55 PM
No. The frame rate is always 59~60, but the vision jumps.
Old 07-28-2010, 08:52 PM
You mentioned this also happens when the tracking data is not used. Does this happen with standard mouse navigation and a simple model like the following?
If not, can you post a sample script that replicates this without using tracking data?
Old 07-29-2010, 12:05 AM
In your sample code, vision jumping does not happen.
Following is my code.
viz.add('court.ive')
viz.collision(viz.ON)
evart = viz.add('evart.dle',0,'192.168.0.3')
body = evart.getBody(0)
link = viz.link(body,viz.MainView)
Old 07-29-2010, 01:43 PM
Does this jump occur when the body is still or only when it's moving? How far is this jump?
What is happening the EvaRT GUI, do you see the body jumping from one position to another? Is the body getting occluded?
Old 08-01-2010, 07:16 AM
It always occurs, whenever vision is moving or not.
How far is... about 4,5 cm?
If you want, I can send a movie that shows vision jumping.
In evart, there is no problem. The body never jump.
Old 08-02-2010, 11:25 AM
Please upload a movie to the following:
http://www.worldviz.com/support/upload.html
