Old 06-28-2010, 01:26 PM
Mike@vrs Mike@vrs is offline
Lite version of vizard purchased
Hi Guys
Just purchased the lite version to extend my experience of vizard.
I take it that this version is unable to create/publish to an .exe file
Old 06-28-2010, 01:33 PM
You should be able to create a publish EXE with the trial/lite versions. The only restriction is that the EXEs will automatically exit after 2 minutes.
Old 06-28-2010, 01:34 PM
When I try to publish an .exe it asks me to contact support?
Old 06-28-2010, 01:44 PM
This error usually occurs when you attempt to create the EXE in a directory that you don't have write permissions on. If this is the case, then try changing the path of the EXe when publishing to your users desktop. Let us know if this doesn't fix your problem.
Old 06-28-2010, 02:35 PM
Sucessful exe publised
Yes thanks.
I recreated the exe to the desktop and although I had to add the video as an additional file prior to publishing it worked ok. Still have the inverted video problem though. However thanks for advice.
OSG version number in Vizard 3.0 vijaykiran Vizard 1 09-09-2009 12:03 PM
just downloaded Vizard Lite - crashes upon startup... bernie Vizard 6 11-23-2008 09:56 AM
Lite Version? Sandro Holzer Vizard 3 07-23-2008 02:08 AM
Next version of Vizard bailenson Vizard 1 08-04-2004 05:45 PM
