Getting camera position from ive
Hi All
Im trying to get the camera position from an .ive file. i thought the following code would work modela = viz.add("Test.ive") print modela.getChild("Camera01").getPosition() However it only returns [0.0, 0.0, 0,0] Is there a way of doing this? Thanks |
The camera data is not exported. One way of doing this is create a box and link it to the camera in Max. You could make the box invisible in Max by assigning a fully transparent material to it or you could make the box invisible in Vizard. Then you can use the GEODE of the box to get the camera position. Take a look at the following kb article which talks about getting a handle to a GEODE.
http://kb.worldviz.com/articles/1157 |
| writing joystick position to a data file | Saz | Vizard | 3 | 12-17-2008 06:18 AM |
| Connecting vizard to a camera | dan12345 | Vizard | 1 | 11-11-2008 04:09 PM |
| default start position | erchrastil | Vizard | 2 | 06-23-2008 09:15 AM |
| position of html-file on screen | active_world | Vizard | 1 | 05-16-2008 08:24 PM |
| Avatar always returns in initial position | pattie | Vizard | 2 | 08-31-2006 09:15 PM |
