Old 04-01-2010, 11:47 AM
Enlil Enlil is offline
Blending and getting an individual texture from a face
I am blending textures on a .vzf face added using body.addFace. This worked pretty well until the artist started using facegen, which wants to generate multiple texture files for the face. Using the blend example, I am blending using code like:
        self.blend = viz.add('multitexblend.fp')
        self.VizFaceObject.apply(self.blend)
        self.NeutralTextureFileName = file1
        self.Texture1 = viz.add(textureFile1)
        self.Texture2 = viz.add(textureFile2)
        self.VizFaceObject.texture(self.Texture1)
        self.VizFaceObject.texture(self.Texture2, '', 1)
        self.blend.param(0,0)
However, this replaces all the textures in the face (so in my particular case, the eyeball texture is replaced with the texture I am setting on the face . . .)
So, is there a way to blend only the skin texture? And if so, how do I access it?
Christian
Old 04-01-2010, 01:39 PM
When applying the texture and fragment program, specify the sub-node that the skin texture is applied to. For example:
face.apply(blend,'skin_geom')
face.texture(tex1,'skin_geom')
face.texture(tex2,'skin_geom',1)
You will need to replace 'skin_geom' with the actual name of you skin sub-node.
Old 04-09-2010, 12:12 PM
Thanks, that works.
Christian
