Old 01-24-2009, 09:13 AM
reedev reedev is offline
How do I add custom functions to a custom plugin?
I am working on CustomNode plugin. I have my custom node up and running fine.
Now I would like to add my own functions to the plugin. Can anyone show me how that's done? It's not in the CustomNode example.
Thanks a lot.
Best regards
Raymond
Old 01-26-2009, 06:46 PM
Here is a small example that uses the skydome plugin to show how to customize a plugin object. Usually you create your own Python module that specifies your class. In this example, create a file called SkyDome.py and add the following code to it:
class SkyDomeClass(viz.VizCustomChild):
	def myfunc(self):
		self.command(1)
viz.upgradeCustomNode('skydome.dlc',SkyDomeClass)
def addSkyDome():
	return viz.add('skydome.dlc')
The following code shows how to use your new module:
dome = addSkyDome()
dome.myfunc()
Old 01-27-2009, 06:27 AM
Aha, ok, it's starting to make sense...
This command is then calling the C++ class func
void CommandCustomNode(void *custom) ? (from the CustomNode example)
Is there not a direct way of calling the CommandCustomNode() func? Isn't it exposed via the python module?
thanks
Raymond
Old 01-27-2009, 08:07 AM
Also, I would like to specify arguments when the plugin is loaded, so that I can specify these arguments to my constructor.
thanks,
Raymond
Old 01-27-2009, 06:37 PM
When you create the custom node object, you can optionally specify additional arguments:
mynode = viz.add('mynode.dlc',command,mesg,x,y,z,w)
You can also send additional commands to the node once it is created:
mynode.command(command,mesg,x,y,z,w)
The command, mesg, x, y, z, w values are part of the VizCustomNodeObj structure that is passed to your C++ function.
Old 01-28-2009, 01:16 AM
So this way I don't need to create a python class, right?
I like the last way better.
Thanks a lot
Raymond
Old 01-28-2009, 04:31 PM
You don't have to create a Python class for you custom nodes. Wrapping your custom commands with proper functions usually makes the code easier to read, and this is the main reason to do it. It's 100% optional though.
Old 02-01-2009, 04:39 AM
It's all clear to me right. And working :-)
Thanks a lot for your support.
Best regards
Raymond
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 01:24 AM
Custom Render .EXE export vaestebob Plug-in development 2 05-12-2008 08:55 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 11:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 10:23 PM
