Old 11-18-2008, 01:11 PM
TrashcanPatrol TrashcanPatrol is offline
Saving/Loading data
Hi, I've been wondering what is possible with Vizard to do in the case of saving and loading data?
I've found a post here that shows how to output the keystrokes to a text file, but I'm trying to save things such as what options were selected at a text box, if the player has already "talked" to an avatar, etc.
What are the options for this?
Old 11-19-2008, 11:24 AM
Here's a link to a tutorial on creating data files. If you have further questions on writing your data to file let me know.
http://www.worldviz.com/vizhelp/Creating_data_files.htm
Old 12-02-2008, 03:23 PM
The code is not working for me... I keep getting this error from it:
File "<string>", line 11, in ?
File "quest.py", line 85, in ?
score_data = open('quest_data','a')
TypeError: 'VizText' object is not callable
Old 12-02-2008, 03:59 PM
This means you have assigned a text object to a variable named open, which conflicts with the built-in Python function. You should rename your text objects to something less generic.
Old 12-04-2008, 01:20 PM
The tutorial mentioned above uses the same code and it works, though...
import time
subject = viz.input('What is the participant number?')
viz.add('duck.cfg').translate(0,0,4)
critical_question = viz.add(viz.TEXT3D,'Do you see a duck?',viz.SCREEN)
yes = viz.add(viz.TEXT3D, 'Yes!',viz.SCREEN)
no = viz.add(viz.TEXT3D, 'No!',viz.SCREEN)
critical_question.alignment(viz.TEXT_CENTER_TOP)
critical_question.translate(.5,.9)
yes.alignment(viz.TEXT_LEFT_TOP)
yes.translate(.25,.75)
no.alignment(viz.TEXT_LEFT_TOP)
no.translate(.75,.75)
yes_button = viz.add(viz.BUTTON)
yes_button.translate(.22,.71)
no_button = viz.add(viz.BUTTON)
no_button.translate(.72,.71)
start_time = time.time()
question_data = open('duck_data','a')
def onbutton(obj,state):
    #Use our starting time variable to find out how much
    #time has elapsed.
    elapsed_time = time.time() - start_time
    #Create string lines to put in the data file, depending on which
    #button was pushed.
    if obj == yes_button:
        data = 'Subject ' + str(subject) + ' saw a duck.'
    if obj == no_button:
        data = 'Subject ' + str(subject) + ' did not see a duck.'
    #Write the data to our file.
    question_data.write(data)
    #Flush the internal buffer.
    question_data.flush()
    #Close the world.
    viz.quit()
viz.callback(viz.BUTTON_EVENT,onbutton)
In this, the file they're trying to open is duck_data; my file is called score_data, is that too generic?
Old 12-05-2008, 04:02 PM
the problem is not the name of your file, score_data. Somewhere else in your script you have a variable named open. You'll just need to give that a new name
Old 12-09-2008, 03:04 PM
Ah yes, I looked around for 'open' and it seems I had forgotten that I had a text object outside of the script so it was on the stage. No wonder I was having so much trouble finding it... thanks for the help!
Old 06-20-2012, 10:29 AM
billjarrold billjarrold is offline
thanks - saved me time
thanks for making this post. it saved me a lot of debugging time!
Crashing when I select Tracker option GoldenSun Vizard 4 07-01-2008 11:06 AM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
data glove navigation arielasso Vizard 6 10-24-2007 02:15 PM
Data Files betancourtb82 Vizard 6 05-04-2006 02:43 PM
