Old 04-02-2008, 06:57 AM
atuin atuin is offline
Installation fails for 3ds max 2008
I tried to install the Vizard 3.0 - Cal3D Exporter for 3ds Max 2008, german
The setup doesn't recognize the 3ds-istallation, it is a german version, using a license server.
I am using Windows XP pro, german, 32bit, SP2.
In the registry are following entries:
HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/MAX-1_407
HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/ObjectDBX
Is there a way to install the plugin manually?
Old 04-02-2008, 09:04 AM
Try temporarily renaming the registry key from HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/MAX-1_407 to HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/MAX-1:409 and then running the installer. Hopefully this will work.
Old 09-13-2008, 01:17 AM
luakt luakt is offline
How to install vizard253_max8_cal3.zip files?
Dear Sir,
The read me file asks us to copy the cal3d.dll, cal3d_max_importer.idi and cal3d_max_exporter.ide to the plug in directory:
c:\program files\autodesk\3dsmax 2009\plugin.
I follow this. Is this the so-called installation? Any way, it does not work.
Do I need to manually modiy the registry?
Old 09-13-2008, 06:23 AM
mspusch mspusch is offline
It seems like you are trying to install the installer for 3DSMax 2008 (you name it in the title of your post: vizard253_max8_cal3.zip ) with
3DSMax 2009 c:\program files\autodesk\3dsmax 2009\plugin.
The installer vizard253_max8_cal3.zip is ONLY for 3DSmax8 and for Vizard 2.5xxx versions.
Please kindly use Vizard3.xx and the correct installer for installing with 3DSMax 2009.
Old 09-13-2008, 10:16 AM
Cannot find exporter for max 2009
I am sorry that I cannot find cal3d exporter for 3ds studio max 2009. Please tell me where I can find the programs and also how to instal.
Many thanks!
Old 09-13-2008, 10:22 AM
Under download - vizard - Vizard 3.0 Exporters:
"Cal3D Exporter for Max 6 to 2009"
