Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 08-20-2008, 05:10 AM
Karla Karla is offline
Randomly and Continuously Change Avatar's Face Texture
I would like to make a Sequence that Waits 2-6sec., Randomly changes the texture on the avatar's face, and Repeats.
Based on the post
http://www.worldviz.com/forum/showthread.php?t=776
the texture needs to be set to repeating mode.
Otherwise, the face is blacked out.
See attached files and code.
Karla
#August 19th, 2008
import vizinfo	#For info box
import viztask 	#For wait time
import random	#For random.choice(), etc.
#****ADD CHARACTER HERE****
#Character M-0327
mv_x = 0; mv_y = 1.78; mv_z = -1.0; viz.MainView.setPosition(mv_x,mv_y,mv_z)
mv_euler_x = 180; mv_euler_y = 0; mv_euler_z = 0; viz.MainView.setEuler(mv_euler_x,mv_euler_y,mv_euler_z)
character1 = viz.add('male.cfg'); character1.translate(0,0,-1.4572); character1.rotate(0,1,0,0); character1.state(1) #Neutral state of avatar
face1 = character1.face('M-0327.vzf')	#add a face to the avatar
eyes_center = viz.add('M-0327Bio_UV_Head.jpg'); face1.texture(eyes_center); eyes_center.wrap(viz.WRAP_S,viz.REPEAT); eyes_center.wrap(viz.WRAP_T,viz.REPEAT)
view1 = viz.get(viz.MAIN_VIEWPOINT)
#Make the avatars' eyes Blink at slightly different rates*****************
#MUST ADD LITERATURE REFERENCES FOR DURATION BETWEEN BLINKS, DURATION OF CLOSE, & DURATION OF OPEN
close_eye = vizact.morph("blink",1,0.1)		#Closing Blink morph, take 0.1sec. to close
open_eye = vizact.morph("blink",0,0.2) 		#Opening Blink morph, take 0.2sec. to open
wait_blink = vizact.waittime(vizact.randfloat(4,10)) 	#Wait 4-10sec. between blinks, less duration for easier tasks (talking), more duration (up to 15sec.) for more difficult tasks
blinkAction = vizact.sequence(wait_blink, close_eye, open_eye, viz.FOREVER) #Blink indefinitely
#Add blink action to face; different avatars will have a slightly different blink rate
face1.addAction(blinkAction, pool=12)
#Use 4 positions (Left, Right, Center, and Up) to create different Eye Contact
#l_eyes = viz.add('M-0327_eyes_Left.jpg') 		#modified face, 'eyes' to Left
#r_eyes = viz.add('M-0327_eyes_Right.jpg') 		#modified face, 'eyes' to Right
#c_eyes = viz.add('M-0327_eyes_Center.jpg') 	#modified face, 'eyes' Center (default)
#u_eyes = viz.add('M-0327_eyes_Up.jpg') 		#modified face, 'eyes' Up
l_eyes = viz.addTexture('M-0327_eyes_Left.jpg') 	#modified face, 'eyes' to Left
r_eyes = viz.addTexture('M-0327_eyes_Right.jpg') 	#modified face, 'eyes' to Right
c_eyes = viz.addTexture('M-0327_eyes_Center.jpg') 	#modified face, 'eyes' Center (default)
u_eyes = viz.addTexture('M-0327_eyes_Up.jpg') 		#modified face, 'eyes' Up
#TRYING TO DEFINE A SEQUENCE THAT RANDOMLY CHANGES THE TEXTURE ON THE AVATAR'S FACE
#Intention: Make a Sequence that Waits 2-6sec., Randomly changes gaze, Repeats
#Applies a texture for first assignment of "position"
gaze_duration = vizact.waittime(vizact.randint(2,6)) #Mean of gaze duration is 4sec., Wait 2-6sec. between changes in gaze
position = random.choice([l_eyes, r_eyes, c_eyes, u_eyes])
GazeAction = vizact.sequence(gaze_duration, face1.texture(position), position.wrap(viz.WRAP_S,viz.REPEAT), position.wrap(viz.WRAP_T,viz.REPEAT), viz.FOREVER) #Change gaze indefinitely
#Under "Dynamic Parameters" in Vizard Help, found the following suggestions
#gaze_duration = vizact.waittime(vizact.randint(2,6)) #Mean of gaze duration is 4sec., Wait 2-6sec. between changes in gaze
#position = random.choice([l_eyes, r_eyes, c_eyes, u_eyes])
#ApplyTexture = vizact.texture_node(position)
#GazeAction = vizact.sequence(gaze_duration, ApplyTexture, position.wrap(viz.WRAP_S,viz.REPEAT), position.wrap(viz.WRAP_T,viz.REPEAT), viz.FOREVER) #Change gaze indefinitely
#Applies a black texture, need REPEAT in GazeAction
#textures = [l_eyes, r_eyes, c_eyes, u_eyes]
#ApplyTexture = vizact.texture_node(vizact.choice(textures,vizact.RANDOM))
#GazeAction = vizact.sequence(gaze_duration, ApplyTexture, viz.FOREVER) #Change gaze indefinitely
#Also tried following code in different combinations with no success
#print position
#position = vizact.choice([l_eyes, r_eyes, c_eyes, u_eyes],vizact.RANDOM)
#position = vizact.choice(["l_eyes", "r_eyes", "c_eyes", "u_eyes"],vizact.RANDOM)
#viz.getOption(position, default="u_eyes")
#GazeAction = vizact.sequence(gaze_duration, position = random.choice([l_eyes, r_eyes, c_eyes, u_eyes]), face1.texture(position), position.wrap(viz.WRAP_S,viz.REPEAT), position.wrap(viz.WRAP_T,viz.REPEAT), viz.FOREVER) #Change gaze indefinitely
#GazeAction = vizact.sequence(gaze_duration, face1.texture(position), viz.FOREVER) #Change gaze indefinitely
#textures = ["M-0327_eyes_Left.jpg", "M-0327_eyes_Right.jpg", "M-0327_eyes_Center.jpg", "M-0327_eyes_Up.jpg"]
#position = vizact.choice(textures,vizact.RANDOM)
#Add Avatar speech Actions with .wav files********************************
Story = vizact.speak("00Demo1_My_grandpa's_snoring_Story.wav", scale=0.01, sync=True)
length_story_sec = (71)	#Number of seconds in Story .wav file (66) plus 5 seconds
#vizact.speak(filename, scale=1.0, morph='mouth_open', threshold)
def changeEyesDuringStory():	#Automatically loop through direction of gazes
	#Set variables
	count = 0
	pool_number = 3
	while count <3:
		face1.addAction(GazeAction, pool=10)
		yield viztask.waitTime(2)		#Wait 2 seconds, v3.0+
		character1.addAction(Story, pool=pool_number);
		yield viztask.waitTime(length_story_sec)		#Wait seconds; based individually on length of story
		#***Story Question***
		QuestionBox = vizinfo.add("")		#Add the vizinfo object
		QuestionBox.translate(1.0,.90) 		#Set position on screen, down lower for longer title
		QuestionBox.title("Who's snoring \nkept me awake?")
		invisibleRadio = QuestionBox.add(viz.RADIO, 0, "")	#Create an invisible Radio button to be the default selected one, so that one of the visible ones must be chosen by the user
		invisibleRadio.visible(0) #invisible
		aRadio = QuestionBox.add(viz.RADIO, 0, "A.  My nephew's snoring")
		bRadio = QuestionBox.add(viz.RADIO, 0, "B.  My grandpa's snoring")	#want a button or box that will be empty at first but can have only one selected when the OK button is pressed
		cRadio = QuestionBox.add(viz.RADIO, 0, "C.  My father's snoring") 	#not using checkboxes because a user can check more than one
		OKbutton = QuestionBox.add(viz.BUTTON, "OK")		#Create a button
	count +=1
#Schedule task to start changing eye gaze around while telling story
viztask.schedule(changeEyesDuringStory())
ID:	260   Click image for larger version
ID:	261   Click image for larger version
ID:	262   Click image for larger version
Old 08-21-2008, 10:50 AM
Here is some sample code that uses the vizact library to create an action that does what you want.
#Create quad for displaying texture
quad = viz.addTexQuad(pos=(0,1.8,2))
#List of texture filenames
files = ['ball.jpg','gb_noise.jpg','brick.jpg','lake3.jpg']
#List of texture objects
textures = [ viz.addTexture(f) for f in files ]
#Create action that randomly waits between 2-6 seconds
waitTime = vizact.waittime( vizact.randfloat(2.0,6.0) )
#Create action that randomly applies texture from list above
randomTexture = vizact.texture_node( vizact.choice(textures,vizact.RANDOM) )
#Create sequence that repeats above actions indefinitely
my_action = vizact.sequence( waitTime, randomTexture, viz.FOREVER )
#Add action to quad
quad.addAction(my_action)
Old 08-22-2008, 09:00 AM
Avatar's face blacked out
Thanks for the suggestion. It works for quad objects but not for the avatar's face.
The avatar's face becomes blacked out when the texture is applied. There seems to be a difference between applying a texture to an avatar's face and applying it to other objects. I am having a similar problem as in post
Using 'texture.wrap(viz.WRAP_S,viz.REPEAT), texture.wrap(viz.WRAP_T,viz.REPEAT),' applies the texture correctly to the avatar's face. Therefore, it is not blacked out when using 'wrap.'
How can I incorporate 'wrap' with the random texture application? An error message said "'ActionData' object has no attribute 'wrap'."
Karla
[/CODE]
#August 22nd, 2008
#Orient view to look at avatar
#Create avatar for displaying texture
eyes_center = viz.add('M-0327_eyes_Center.jpg'); face1.texture(eyes_center); eyes_center.wrap(viz.WRAP_S,viz.REPEAT); eyes_center.wrap(viz.WRAP_T,viz.REPEAT)
files = ['M-0327_eyes_Left.jpg','M-0327_eyes_Right.jpg','M-0327_eyes_Center.jpg','M-0327_eyes_Up.jpg']
#Add action to avatar
face1.addAction(my_action)
#ERROR: Avatar's face is Blacked-out; need to set texture to repeating mode
#Try setting texture to repeating mode
#files = ['M-0327_eyes_Left.jpg','M-0327_eyes_Right.jpg','M-0327_eyes_Center.jpg','M-0327_eyes_Up.jpg']
#textures = [ viz.addTexture(f) for f in files ]
#waitTime = vizact.waittime( vizact.randfloat(2.0,6.0) )
#randomTexture = vizact.texture_node( vizact.choice(textures,vizact.RANDOM) )
#my_action = vizact.sequence( waitTime, randomTexture, randomTexture.wrap(viz.WRAP_S,viz.REPEAT), randomTexture.wrap(viz.WRAP_T,viz.REPEAT), viz.FOREVER )
#face1.addAction(my_action)
#ERROR: Message says 'ActionData' object has no attribute 'wrap'
Old 08-22-2008, 09:39 AM
Then set the the textures to repeat mode when you add them:
textures = [ viz.addTexture(f,wrap=viz.REPEAT) for f in files ]
Old 08-22-2008, 12:14 PM
THANK YOU! THANK YOU! That code solves what I want.
