Old 07-26-2008, 03:36 PM
roman_suvorov roman_suvorov is offline
Question Sound doesn't play from director functions
Hello, when running a sample script like this one:
def playSound():
	sound = viz.addAudio("quack.wav")
	sound.play()
	return
viz.director(playSound)
.. no sound is played and the following error message is displayed:
** ERROR: Failed to create graph builder (CoInitialize has not been called. )
** ERROR: Failed to load audio 'quack.wav'
However, this works fine:
sound.play()
.. so I figured this must have something to do with Vizard's handling of director functions. Any ideas?
Old 07-29-2008, 10:59 AM
You need to add the sound object in the main thread. Once it is added you should be able to play it in other director threads.
If it is necessary for you to add the sound object in the director thread, then you can install the pywin32 library for python and use the following code:
import pythoncom
def playSound():
	pythoncom.CoInitialize() #Initialize COM
	sound.play()
	pythoncom.CoUninitialize() #Uninitialize COM
	return
Old 07-29-2008, 01:25 PM
If it takes a while to add the sound, would there be a frame rate blip on the add?
What if you added a 3D model with this method?
Paul Elliott
WorldViz LLC
Old 07-29-2008, 03:28 PM
If the audio takes a while to load, then adding the file during runtime will cause a stall in the framerate. In this case, you would use the modified version of the director function I posted above. This is not the case for 3D models though, they can be added as usual in director functions. The call to pythoncom.CoInitialize() is only necessary for COM/DirectX related objects.
Old 07-31-2008, 09:31 AM
Thanks farshizzo, very helpful as usual. Works flawlessly now.
Sound Looping Problem JMOwens Vizard 4 09-29-2010 10:42 PM
On click Sound Play Problems Robbos Vizard 1 02-28-2008 03:02 PM
Stuttering sound Jerry Vizard 1 06-13-2007 01:36 PM
Sound in one ear only? Jerry Vizard 1 06-29-2006 05:26 PM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
