Old 07-10-2008, 08:45 AM
Andrey Andrey is offline
e.obj2 in collisions
There is a set of objects described as a list with the members which are direct instances of a class. These objects are e.obj2 in collisions. Could you recommend how to register the collision with certain object by means of its class variable?
Thank you,
Andrey
Old 07-10-2008, 11:24 AM
Sorry, I don't understand what you are trying to do. Can you be more specific?
Old 07-10-2008, 01:12 PM
Sorry for the puzzle. So I have a number of objects (balls) described in the script as the list segmSet[]. Each object was generated as the instance of class. While colliding with a hand moving pointer object (which is e.obj1) such a ball (which is e.obj2) should change the color to orange and class variable segmSet[].selected associated with this object should be changed. No problem with color:
e.obj2.color(viz.ORANGE)
but if I try something like
if e.obj2 in segmSet:
to change segmSet[].selected, it does not work.
Old 07-10-2008, 06:54 PM
It's still not clear what the problem is. Can you post a small sample script that recreates the problem you are having so that I can run it here?
Camera collisions with duckcourt code shivanangel Vizard 2 03-14-2008 11:46 AM
