Old 11-17-2007, 06:24 AM
Murilo Murilo is offline
Visible On/Off for a "menu"
Hi... I'm trying to make visible or not pushing a key for a future menu...
menuScene = viz.addScene()
menuView = viz.addView()
menuView.setScene(menuScene)
menuWindow = viz.addWindow()
menuWindow.setClearMask(viz.GL_DEPTH_BUFFER_BIT)
menuWindow.setPosition(0,1)
menuWindow.setSize(1,1)
menuWindow.viewpoint(menuView)
#Create root node for menu quads
menu = viz.addGroup(scene = menuScene)
menu.translate(0,1.8,5)
#Create texture to apply to quads
tex = viz.addTexture('ball.jpg')
quad = viz.addTexQuad(parent=menu)
quad.texture(tex)
quad.alpha(0.7)
vizact.onkeydown( 'a', menuScene.visible(viz.ON) )
vizact.onkeydown( 's', menuScene.visible(viz.OFF) )
viz.add('gallery.ive')
When I push 'a' or 's', show this:
File "C:\Arquivos de programas\WorldViz\Vizard30/python\vizact.py", line 2667, in __onkeydown
self._callGroup(self.__keydownmap[key])
File "C:\Arquivos de programas\WorldViz\Vizard30/python\vizact.py", line 2619, in _callGroup
val = e.call(arg)
File "C:\Arquivos de programas\WorldViz\Vizard30/python\vizact.py", line 2470, in _callStatic
return self.func(*self.args,**self.kwargs)
TypeError: 'NoneType' object is not callable
What can I do!?
thanks,
Murilo
Old 11-17-2007, 06:30 AM
I found a way!
quad.texture(tex)
quad.alpha(0.7)
def press(key):
	if key == 'a':
	if key == 'b':
viz.callback(viz.KEYBOARD_EVENT, press)
Old 11-19-2007, 09:11 AM
The problem with the original code was that you were using the vizact.onkeydown command incorrectly. It should be:
vizact.onkeydown( 'a', menuScene.visible,viz.ON)
vizact.onkeydown( 's', menuScene.visible,viz.OFF)
The second parameter to the command needs to be a function object. All other parameters will be passed to the function when the specified key is pressed.
Visible and alpha commands mjabon Vizard 1 08-27-2007 09:21 AM
texblend or visible for multiple textures vizmaster Vizard 10 02-14-2007 03:50 PM
on/off button bailenson Vizard 1 09-28-2004 05:13 PM
