Old 10-03-2007, 08:06 AM
JMOwens JMOwens is offline
3 Easy Questions
Hi folks,
Well, I hope they're easy questions! I'm trying to get Vizard set up with our new Kaiser SR80A, and there are a few small bugs. If you please:
1) viz.ipd doesn't seem to do anything. I want the user to be able to input each subject's ipd, and have vizard automatically use that value. Here's what I have:
eyeohd = viz.input('What is the participants IOD, in mm?')
viz.ipd(eyeohd/100)
What am I doing wrong? In the help file Vizard mentions viz.setipd, but that doesn't seem to be supported.
2) What the difference between viz.HMD and viz.FULLSCREEN? I had been using viz.go(viz.STEREO|viz.FULLSCREEN), but should I be using viz.HMD? What does it do?
3) Is there an easy way to change the position of a dialog box on the screen? Since I'm simultaneously displaying onto dual monitors and into the HMD, my initial input boxes pop up across the two displays, so they're unreadable. I have several user inputs, set up as in question 1 above.
Thanks so much for your help, Vizards!
Justin
Old 10-03-2007, 10:58 AM
1) I believe you might be entering the ipd as an integer. In python, integer division will yield another integer. So the computed ipd is most likely 0. You need to divide the ipd by a floating value. Also, Vizards units are in meters, so you need to divide the input mm ipd by 1000. The following code should fix your problem:
viz.ipd(eyeohd/1000.0)
2)You should use viz.HMD if the user is wearing an HMD. viz.HMD will go into fullscreen mode and use symmetric view frustums for each eye.
3)Sorry, there is currently no way to change the position of the dialog popups.
Old 10-03-2007, 01:00 PM
Great, thanks farshizzo! I forgot about the integer thing...
And I would respectfully suggest adding a way to re-place the dialog boxes in future revisions - I would imagine that dual monitors/HMD is a common setup among your users, and it's impossible to read dialogs this way. Thanks!
Old 10-03-2007, 01:10 PM
Thanks for the suggestion, we will try to include this option in a future release.
