Old 10-17-2006, 01:26 PM
felixchc felixchc is offline
displayhtml did not work after published as EXE
Could you help to check if the displayhtml command is not function after publish to EXE file? I just add very basic code to show a dummy html page, it works by using RUN command but simply shows nothing on the EXE file.
Thanks.
Felix.
Old 10-17-2006, 01:48 PM
You are correct, the html files are not automatically added to the the exe. You can manually add the html files to the exe by dragging/dropping the files onto the publish file list.
Old 10-17-2006, 01:58 PM
Thanks for your quick answer.
Just tried adding the html file onto the exe file list and publish, still shown nothing.
Old 10-17-2006, 02:06 PM
Can you post the code you are using to display the html file?
Old 10-17-2006, 02:14 PM
Sorry, I forgot to mention that you need to add the VizHTMLViewer.exe file as well. It is located in the Vizard30/bin directory. We will be releasing a new beta version sometime this week, and it will include a fix that will automatically add this file for you.
Old 10-18-2006, 01:33 AM
The method works great. Many thanks for your quick answer.
