Old 10-12-2006, 11:51 AM
problem with stereo mode
Hi again,
I'm having a problem getting into stereo mode.
I have two demo's. The first demo runs just fine.
The second demo involves manipulating the camera's location with a game pad. However, whenever I try to use viz.QUAD_BUFFER, I don't get stereo mode.
Here is my code:
##Name     :George D. Lecakes Jr
##Created  : October 11, 2006
##Modified : October 11, 2006
##Descr    : 	This program creates a viewport that centers around
##				the translational properties of an object similar
##				to that of a video game.
##Game Pad Library Information
import sid
viz.go(viz.QUAD_BUFFER)
viz.viewdist(-5)
#Global Variables
##Height from Interest
H = 0
##X from Interest
R = 0
##Z from Interest
I = 0
##Reference Plane
envio = viz.add('coords.obj')
envio.translate(0,-3,0)
#Model of Interest
modelOfInterest = viz.add('templateModel.obj')
##Create a new viewpoint
objectTracker = viz.add(viz.VIEWPOINT)
##Get and set the main window to the viewpoint
mainWindow = viz.get(viz.MAIN_WINDOW)
mainWindow.viewpoint(objectTracker)
##Initialize Elements
##Object Of Interest
interestx = 0
interesty = 0
interestz = 0
modelOfInterest.translate(interestx,interesty,interestz)
##Viewpoint
viewCoordx = 0
viewCoordy = 10
viewCoordz = 20
objectTracker.translate(viewCoordx,viewCoordy,viewCoordz)
#Function Declarations
def georgesTimer(timerNum):
	## Get the translation information of the desired object
	#interest = modelOfInterest.get(viz.POSITION)
	## Get the translation information of the viewpoint
	#viewCoords = objectTracker.get(viz.POSITION)
	## See which gamepad button has been pressed
	global H
	global R
	global I
	global upCheck
	global interestx
	global interesty
	global interestz
	global viewCoordx
	global viewCoordy
	global viewCoordz
	upCheck = 0
	## Up
	if sid.isbuttondown(7):
		diff = viewCoordy - interesty
		##  If view is above interest
		if  diff > 0:
			H = (H + .1)
			viewCoordy = (interesty + H)
		##  If View is below interet
		if diff < 0:
			H = (H + .1)
		## If View is equal to interest
		if diff == 0:
			viewCoordy = 0
			H = (H + .1)
## Down
	if sid.isbuttondown(8):
		if  diff > 0:
			H = (H - .1)
		##  If View is below interest
		if diff < 0:
			H = (H - .1)
			viewCoordy = (interesty - abs(H))
		if diff == 0:
			viewCoordy = 0
			H = (H - .1)
##Forward
	if sid.isbuttondown(3):
		diff = viewCoordx - interestx
		if  diff > 0:
			R = (R + .1)
			viewCoordx = (interestx + R)
		if diff < 0:
			R = (R + .1)
		if diff == 0:
			viewCoordx = 0
			R = (R + .1)
##Backward
	if sid.isbuttondown(2):
		if  diff > 0:
			R = (R - .1)
		if diff < 0:
			R = (R - .1)
			viewCoordx = (interestx - abs(R))
		if diff == 0:
			viewCoordx = 0
			R = (R - .1)
##Left
	if sid.isbuttondown(1):
		diff = viewCoordz - interestz
		if  diff > 0:
			I = (I + .1)
			viewCoordz = (interestz + I)
		if diff < 0:
			I = (I + .1)
		if diff == 0:
			viewCoordz = 0
			I = (I + .1)
##Right
	if sid.isbuttondown(4):
		if  diff > 0:
			I = (I - .1)
		if diff < 0:
			I = (I - .1)
			viewCoordz = (interestz - abs(I))
		if diff == 0:
			viewCoordz = 0
			I = (I - .1)
	objectTracker.lookat(modelOfInterest.get(viz.POSITION))
	print viewCoordx
##CallBack to Functions
viz.callback(viz.TIMER_EVENT, georgesTimer)
viz.starttimer(0,0, viz.PERPETUAL)
Old 10-13-2006, 04:59 PM
Are you able to get QUAD_BUFFER working with other scripts? QUAD_BUFFER stereo mode only works with specific graphics cards, like the nVidia Quadro. Do you have a capable graphics card?
Old 10-17-2006, 08:26 AM
Yes, we are able to get it working with ANY other script we have. As long as we don't start messing with the camera's coordinates directly through scripting things are fine.
But in the code I supplied as well as another camera rig I developed, it will not enter stereo mode. We are were unable to force the 'planets' demo into stereo mode and we were wondering if there might be a similar problem there as well.
~~George
Rowan University
VR Laboratory
Old 10-17-2006, 10:58 AM
I tested out your script with Vizard 2.5 and experienced the same problem you described. I tried it out with Vizard 3.0 and it works fine. The problem is not caused by manipulating the viewpoint, but by adding a new viewpoint to the main window. In your script the workaround would be to replace the following code:
with:
##Get the main viewpoint
objectTracker = viz.get(viz.MAIN_VIEWPOINT)
##Get the main window
