Old 05-23-2006, 05:57 PM
enkeli enkeli is offline
get vertex with on the fly object
Hello, I was wondering if it's possible to get the value of a vertex of an on-the-fly object? I create a line, then scale it, then I need the value of the scaled vertex.
Old 05-25-2006, 12:59 PM
Please help, all I need is a get method for the vertex position. I'm pretty sure the values exist somewhere. Something like:
[ x, y, z ] = myOnTheFlyLine.getVertex( 0 ) # to get the x,y,z of the 0th vertex
[ x, y, z ] = myOnTheFlyLine.getVertex( 1 ) # to get the x,y,z of the 1th vertex
Old 05-25-2006, 03:10 PM
Sadly, Vizard provides no way to get the vertex positions The workaround is to recorde the positions of the vertexes when you add/modify them.
Old 05-25-2006, 03:21 PM
Sadly that workaround would not work for me, as after I set a vertex I scale the object. To get that new point, I would need to do quite a bit of math which I would like to avoid...
Old 05-25-2006, 03:31 PM
Hmm. OK, heres a possible solution: add a child object to the on-the-fly object before you scale it. Translate the child object to the position of the vertex you are interested in. Then scale the on-the-fly object. Then print out the child objects position.
l = viz.add( 'logo.wrl' )
b = l.add( 'ball.wrl' )
b.translate( 1, 0, 0 )
def onkeydown(key):
	l.scale( 3, 3, 3 )
	print b.get( viz.POSITION )
viz.callback(viz.KEYDOWN_EVENT,onkeydown)
Old 05-25-2006, 05:22 PM
Interesting, I shall try it and let you know if it works out.
Old 05-25-2006, 06:38 PM
Hey. I tried it, however the position of the ball, while it appears in the world where it is translated/scaled to, the position values remain the same. :-(
Old 05-25-2006, 06:44 PM
Boy that Vizard is a whily one. Maby I'll have something for ya tomorrow. Something with the new viz.link() functianlity or something.
Paul Elliott
WorldViz LLC
Old 05-25-2006, 07:13 PM
I got it!
b.get( viz.POSITION ) gets the position locally, while
b.get( viz.POSITION, viz.ABSOLUTE_WORLD ) gets what I want :-)
Thanks for the help!
Old 05-25-2006, 08:27 PM
Instead of adding a model, such as 'ball.wrl', add a Group to increase performace and avoid having to remove the ball.
vertexTracker = logo.add( viz.GROUP )
Paul Elliott
WorldViz LLC
