Old 04-10-2017, 07:41 AM
manueleh manueleh is offline
Help with Intersense BT
To whom it may concern,
I am working on using an Intersense BT 3-DOF accelerometer for motion tracking in Vizard 5, and was wondering if the built in intersense plugin can be made to work with this sensor? If not, are there updated tools for creating a custom plugin? Thanks!
Old 04-11-2017, 12:36 AM
rajnishv rajnishv is offline
Hi manueleh,
You may pls find the link from Vizard doc and related posts on World Viz Forum:
Vizard Doc:
http://docs.worldviz.com/vizard/Old_...se_Plug-In.htm
Posts Link on World Viz Forum:
http://forum.worldviz.com/showthread.php?t=43
http://forum.worldviz.com/showthread.php?t=5362
Thank You!!!!
Mr.Rajnish Vishwakarma
Mumbai,Maharashtra,India
Old 04-12-2017, 12:29 AM
I'm not sure if our plug-in works with the Intersense BT. Do you get an error message after running the following code?
isense = viz.add('intersense.dle')
tracker = isense.addTracker()
Old 04-20-2017, 02:21 PM
Further details on error with intersense BT
Hi Jeff,
Running the code provided allows the intersense BT to connect as we are using a standard serial over bluetooth link. However, no data appears to be collected. Should next steps be using the .dll for the intersense to create a custom plugin?
Manuel
intersense, plug-in
intersense addTracker krimble Vizard 4 04-02-2012 10:57 AM
Intersense connection blessonisaac Vizard 2 12-06-2010 06:13 PM
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 12:35 PM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 09:03 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 08:22 AM
