Old 05-23-2016, 11:23 AM
Seadna Seadna is offline
Question HTC Vive Controller not working
Hi there,
I have successfully loaded the example script with the Vive headset working flawlessly. However i cannot seem to get the controllers to work. I ran the example script but cannot see the controllers. The controllers are on and they work in other applications.
Any help is much appreciated.
Old 05-24-2016, 03:22 AM
Are there any controllers returned by the steamvr.getControllerList() command? Does the following print 'connected' for each controller?
import steamvr
hmd = steamvr.HMD()
if not hmd.getSensor():
	sys.exit('SteamVR HMD not detected')
for controller in steamvr.getControllerList():
	print 'connected'
Old 10-22-2016, 08:59 AM
They work now, but only when they are turned on before running my code. Thanks for help.
Old 04-20-2021, 04:10 AM
Roy Roy is offline
I have the same problem.
Although the controller preferences in steamVR is fine, it doesn't work in vizard program.
When I write codes as below,
	print 'vive controller connected'
vizconfig.register(controller)
vizconfig.getConfigWindow().setWindowVisible(True)
for device in steamvr.getControllerList(): #check VR device
	print device
it says
steamvr.dle              	SteamVR Extension
__builtin__.SteamVRController(1)
vizconfig shows the window as attached image, but any keys don't work. Also, I tried viztask.waitSensorDown(controller, steamvr.BUTTON_TRACKPAD), but it never work.
Old 04-21-2021, 07:40 AM
sado_rabaudi sado_rabaudi is offline
Hi Roy,
If you go to tools- vizconnect and choose the SteamVR preset, then go to start page- advanced- inputs do you see a green button or red x next to the r_hand_input and l_hand_input?
Also, the controllers are showing as lit up in SteamVR?
Best,
Sado
controller, htc vive, issue
PPT markers off in Vive? pitbool Precision Position Tracker (PPT) 4 06-09-2016 11:20 PM
xbox one controller as tracker bbb Vizard 4 01-18-2016 07:17 AM
XBOX360 USB controller intermittently working fivel_lab Vizard 2 01-26-2015 07:09 PM
XBOX One Wireless Controller JB_HP_Viz Vizard 1 07-08-2014 05:45 AM
PS3 controller Darkmax Plug-in development 2 02-26-2010 11:57 AM
