Old 03-04-2016, 07:41 AM
Novakin Novakin is offline
Force drawing of a node/model outside of clip / view frustum?
I'm trying to always draw a specific model, regardless of the clip or view frustum setting.
For example, if the camera is at (0, 0, 0), my model is at (0, 0, 5) and the clip is set by calling viz.clip(10, 100), then the result is that my model doesn't get drawn. This is all fine and how it should be. But is there a way to force that specific model or node to always get drawn regardless of the clip setting?
Old 03-07-2016, 01:43 AM
Perhaps the following code will be helpful. It seems to get a bit tricky when other nodes are partially clipped or are in line with the node that is always drawn:
viz.MainWindow.clip(10,1000)
ball = viz.addChild('beachball.osgb',pos=[0,1.8,4])
ball.disable(viz.ADJUST_AUTO_CLIP)
ball.disable(viz.DEPTH_TEST)
ball.drawOrder(10)
ball2 = ball.copy(pos=[0.5,1.8,4])
ball3 = ball.copy(pos=[-0.5,1.8,4])
ball4 = ball.copy(pos=[0,1.8,2])
ball5 = ball.copy(pos=[0,1.8,5])
piazza = viz.addChild('piazza.osgb')
Old 03-09-2016, 07:39 AM
That code does indeed do what I'm looking for, but unfortunately it has a bad effect on the model causing it to show small transparent bits in some places. I'm guessing that's because of the disabling of viz.DEPTH_TEST.
Thanks for the reply, I'll try to work around it for now.
Old 03-09-2016, 07:46 AM
Try changing:
ball.drawOrder(10)
to:
ball.setTransparentDrawOrder()
That might help with the transparency issue.
Old 03-10-2016, 01:51 AM
I'll add a bit of background info. I'm trying to draw the default Vizard gloves (viz.add('glove.cfg') and viz.add('glove_left.cfg')) as my hands using the Razer Hydra. This works great when I set the clip range to something like (0.1, 1000). However, the world we're visualizing is BIG, and a clip range of (10, 100000) is what we're using if we're not using the Hydra (and not showing gloves) but just keyboard and mouse. (Note: can't use a clip range of something like (0.1, 100000), because then we get z-fighting).
So what I'm trying to achieve is use the same big clip range, but then force draw the gloves up close. The code above (in your first and second posts) almost works, but still shows some 'glitches' in the gloves when you're moving and turning them.
If you have any tips, I'm always interested!
frustum versus clip and fov michaelrepucci Vizard 2 08-29-2008 12:50 AM
clip with frustum problem Joran Vizard 1 10-20-2006 11:16 AM
