Old 07-17-2014, 10:03 AM
mshukun mshukun is offline
Handling connected devices
I created an application that requires both the Microsoft Xbox controller and Oculus Rift HMD connections. The Vizard throws error messages in Vizard IDE when these devices are not connected. I would like notify device connection errors to the user using vizinput.message(). Unfortunately, I haven't been able to find the way to do it. I appreciate if you have any suggestions/solutions regarding the problem.
Pseudocode:
IF Both Oculus Rift HMD and Xbox controller are connected
THEN start the application
ELSE
THEN show message and Exit the application
Thank you,
Makiko
Old 07-17-2014, 04:27 PM
The joystick.py example script exits if a DirectInput device is not connected:
If both the display and sensor cables of the Oculus are not connected getSensor will return None:
import oculus
hmd = oculus.Rift()
if hmd.getSensor() is None:
	print 'Rift not connected'
PPT cameras not connected sisun1030 Precision Position Tracker (PPT) 0 03-05-2010 08:02 AM
Bluetooth Devices for Wiimote envisC Vizard 3 10-27-2009 11:09 AM
Multiple Sound Devices GiudiceLab Vizard 2 06-06-2009 10:29 AM
two haptic devices SSophia Vizard 3 07-07-2008 02:42 PM
game devices jkelly Vizard 10 03-27-2007 02:16 AM
