Old 10-08-2013, 09:25 AM
fabioped fabioped is offline
Question Child node coordinates
I have this sample 3ds file with 4 objects:
https://dl.dropboxusercontent.com/u/178438/teste.3ds
How can I see the relative coordinates of these objects?
From this:
def update(a):
p = viz.pick(info=True)
print p.object.getPosition(viz.ABS_GLOBAL)
viz.callback(viz.UPDATE_EVENT, update)
I always see [0,0,0]
using viz.REL_GLOBAL I see the same.
Old 10-09-2013, 03:40 PM
If you open up that model in Inspector and click on each of the sub-parts you'll see that the selection origin does not change. Each sub-part must have it's own transform to return a different position. Take a look at the video tutorial in the Hierarchical Models article. That shows an example of setting up the hierarchy in Max and getting the absolute positions of sub-parts in Vizard.
Texture Coordinates in a Cube Map mshukun Vizard 2 05-10-2013 01:31 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 11:20 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 11:44 AM
trouble changing subnode (child node) color, alpha, etc. michaelrepucci Vizard 7 01-14-2009 09:38 PM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 12:21 PM
