Old 03-14-2013, 01:28 AM
Meneer_Aart Meneer_Aart is offline
avatar walkto interrupt
This maybeIs there a way to stop an avatar that's walking from point A to point B "dead in it's tracks"?
My code untill now looks somewhat like this:
def walk1():
	yield viztask.waitKeyDown( ' ' )
	yield viztask.addAction(avatar, vizact.walkTo([pointA]))
	yield viztask.addAction(avatar, vizact.walkTo([pointB]))
	yield viztask.addAction(avatar, vizact.walkTo([pointC]))
               avatar.state(14)
	yield viztask.waitTime(10)
	viztask.schedule(walk2())
def walk2():
	yield viztask.addAction(avatar, vizact.walkTo([pointD]))
	yield viztask.addAction(avatar, vizact.walkTo([pointE]))
               avatar.state(14)
#main
viztask.schedule(walk1())
So during ANY of the walkto actions i want to be able to stop the avatar where he is, and let him perform some kind of action on that spot.
Old 03-14-2013, 07:04 AM
In the following example the spacebar is used to start and stop the avatar as he walks between two points:
import viztask
viz.add('ground.osgb')
avatar = viz.addAvatar('vcc_male2.cfg',pos=[0,0,9])
avatar.state(1)
walkLeft = vizact.walkTo([2.5,0,9])
walkRight = vizact.walkTo([-2.5,0,9])
walkActions = viz.cycle([walkLeft,walkRight])
waitSpaceBar = viztask.waitKeyDown(' ')
waitLeft = viztask.waitActionEnd(avatar,walkLeft)
waitRight = viztask.waitActionEnd(avatar,walkRight)
waitActions = viz.cycle([waitLeft,waitRight])
def walkAndStopTask():
	yield waitSpaceBar
	while True:
		condition = waitSpaceBar
		walkAction = walkActions.next()
		waitAction = waitActions.next()
		while condition == waitSpaceBar:
			avatar.runAction(walkAction)
			d = yield viztask.waitAny([waitSpaceBar,waitAction])
			condition = d.condition
			if condition == waitSpaceBar:
				avatar.clearActions()
				yield waitSpaceBar
viztask.schedule(walkAndStopTask())
Old 03-20-2013, 02:41 AM
Red face
Thanks for your reply Jeff. I've tried the "clearactions()" statement.
However, since i'm using schedule to arrange the actions, i have to kill that as well to prevent the other walking actions from running.
I've tried this:
def walk1():
               avatar.state(14)
def walk2():
               avatar.state(14)
def stop():
	avatar.clearactions(0)
#main
t = viztask.schedule(walk1())
vizact.onkeydown('l',t.kill)
vizact.onkeydown('k',stop)
And this works, it stops the avatar completely and he returns to his idle state. However, it is inconvenient to have to push 2 keys to stop the avatar, so i tried to add the killing of the schedule to my stop command:
def stop():
               t.kill
But this doesn't work for me, Is there a way to combine the 2 commands? I feel i'm overlooking something very simple here, but i can't quite put my finger on it.
Old 03-20-2013, 02:59 AM
Once the user stops the avatar, what is the next action that should be applied to the avatar? If the avatar stops on the way to PointA, should he pick up from the same place later and continue to PointA, or go to PointB, or should the whole task be ended?
Old 04-02-2013, 07:45 AM
Jeff, i'm writing some software for a military simulation, the avatar actually gets shot and killed.
So the whole task should be ended, i would like the avatar to assume a specific state (lie down) and perform no actions anymore after that.
Old 04-09-2013, 06:39 AM
Not to sound too desperate, but i'm still having some difficulties with this. Does anybody perhaps have a suggestion for me?
Old 04-09-2013, 03:41 PM
If you're waiting for either the walk action to finish or the keypress to occur you should use the viztask.waitAny command. Then if the event was a keypress you can leave the task using the return command:
	return
avatar, interrupt, stop, walkto
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 08:48 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
