Old 08-14-2012, 08:38 AM
nabrahamson nabrahamson is offline
VRPN tracker, detecting device.
Hey Vizard gurus, I have a quick question about your VRPN interface. I have working code using the VRPN tracker with a kinect device. What I want to do is to detect if a kinect is plugged into the computer, and disable the kinect interface if no kinect is found. I see when I run my script the following message if the kinect is not plugged in:
VRPN Error
 (18) from Tracker0: No response from server for >= 10 seconds
Is there a way to programatically detect this error so that I can switch to a different user interface if the Kinect isn't plugged in?
Old 08-14-2012, 08:55 AM
The vrpn objects have a getSampleNumber() and getSampleTime() method for retrieving the number/time of the last received sample. You could setup a timer to check these values and trigger an event if they haven't changed for over 10 seconds.
Old 08-14-2012, 09:17 AM
I've considered this route, but since they don't trigger until the kinect detects another user, it's not really the solution I am going for. In this scenario, the kinect can be plugged in and communicating with FAAST, but there is no user in front of it. The result is a false positive since the two functions mentioned will return 0 and 0.0 even when there is a kinect plugged in and recognized by the system.
Is there a way to catch what vizard is printing to the console? If I had the ability to do that, then I could watch for VRPN Errors, that are being printed out.
Old 08-23-2012, 11:01 AM
That error message is printed deep within the VRPN source. I'm not aware of any way to programmatically detect it, other than modifying the VRPN source.
Old 04-24-2013, 02:03 PM
pankaj bansal pankaj bansal is offline
@nabrahamson
Hey I want to ask if you were able to do this. I also want to do the same and have not find a solution yet..
regards
Pankaj bansal
vrpn
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 01:59 PM
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 10:22 AM
swapPos and swapQuat with VRPN michaelrepucci Vizard 1 07-29-2008 11:27 AM
