Old 02-14-2011, 02:53 AM
Problems with vizhtml displayURL
Hi
the following code works fine
import viztask
import vizhtml
html = """
    <html>
    <body onload="document.the_form.first_name.focus();">
    <form name="the_form" method="post">
        <table>
            <tr>
                <td>First Name</td>
                <td><input type="text" name="first_name"></td>
            </tr>
            <tr>
                <td>Last Name</td>
                <td><input type="text" name="last_name"></td>
            </tr>
            <tr>
                <td></td>
                <td><input type="submit" value="Submit"></td>
            </tr>
        </table>
    </form>
    </body>
    </html>"""
vizhtml.displayCode(html)
def HandleForm(e):
    print "wooho form submited"
vizhtml.onFormSubmit(HandleForm)
However when i change to loading the html file from an external file it doesnt work.
import viztask
import vizhtml
vizhtml.displayURL("simple.html")
def HandleForm(e):
The html is exactly the same just put in the file "simple.html". am i doing something wrong. or is it not mearnt to work like that.
TarkaDahl
Old 02-14-2011, 05:16 AM
The website shows up but the onFormSubmit does not get called.
Old 02-14-2011, 09:34 AM
When loading html files from a URL, instead of code embedded within the script, you must specify the action field of your form. Modifying your form definition to the following should work:
<form name="the_form" method="post" action="http://localhost:8080/vizhtml_form/">
This tells the browser to submit the form data to the vizhtml webserver.
We will update the documentation to mention this.
Old 02-15-2011, 01:45 AM
Hi farshizzo,
That worked.
TarkaDahl
Old 02-17-2011, 08:00 AM
Hi
Here is just a slight problem.
viz.go(viz.FULLSCREEN)
viz.window.displayHTML( 'www.worldviz.com'  )
When i run this code in version 3 everything works as i would expect.
However in version4 i can not click on the html page without it disapearing and the only way i can get it back is by pressing the start menu button.
This only happens in fullscreen mode.
TarkaDahl
Old 02-22-2011, 11:03 AM
Are you running under Windows Vista or 7? There is an issue with some OpenGL drivers under Vista and above where fullscreen mode causes issues like the one you are describing.
Try adding the following line before you call viz.go():
viz.setOption('viz.display.swap_copy',1)
Old 02-22-2011, 01:11 PM
Hi farshizzo
I have just checked that i appears to work. I will check properly on next time im in work.
problems with makepy applications Darkmax Vizard 0 10-12-2010 09:47 AM
problems nagivating around ruby21 Vizard 2 05-18-2010 03:22 PM
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Problems with spawn point. just alex Vizard 1 11-24-2008 09:51 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
