Old 01-11-2011, 09:39 AM
kovitch kovitch is offline
Loading objects faster
I'm using the following code to load some objects:
for i in range(0,tables_number):
	tables.append(viz.add('src/obj/table.flt'))
However, it takes too long to load 50 tables (about 30 seconds).
Is there any trick to accomplish this task faster?
Regards.
Old 01-11-2011, 12:12 PM
You could add the table once and then make copies or clones of it. Check out the section on Duplicating, Copying, and Cloning on the following page:
http://www.worldviz.com/vizhelp/Addi...your_world.htm
Old 01-11-2011, 04:46 PM
Ideally, you should bring the object into 3ds Max, and re-export as an .IVE (OpenSceneGraph), Vizard's native format.
Old 01-11-2011, 05:40 PM
If your script does not require a unique instance for each table, then you can clone all the tables.
for i in range(tables_number):
	tables.append(viz.add('src/obj/table.flt',cache=viz.CACHE_CLONE))
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
multiple objects durf Vizard 1 04-10-2009 02:42 PM
After loading all my objects djdesmangles Vizard 4 06-03-2007 04:23 PM
