Old 09-27-2010, 09:39 AM
Enlil Enlil is offline
Seeing errors finding files in an executable
I am trying to make an .exe that contains a LOT of resources. There are a lot of branching parts, so it is hard to be sure I have every resource. I added some viz.res.addpublish statements, but I believe I am missing some files still.
So, I was wondering, is there a way to see the console output of an executable? Or at least an error log?
Christian
Old 09-27-2010, 11:14 AM
The second dialog in the publish wizard contains a checkbox labelled Display console. You can use this option to display an output console for your published exe.
If you prefer to log the ouput to a file, then you can use the viz.setLogFile command to redirect all output to a file. You will probably want to specify an absolute path if using this command with a published exe.
Old 09-27-2010, 11:34 AM
Thanks, that is very useful!
Christian
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 12:07 PM
Which software can be used to edit .cfg (CAL3D) files luakt Vizard 4 09-12-2008 07:18 AM
Writing text files with executable adimov Vizard 1 03-21-2008 03:21 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
