Old 01-17-2005, 12:47 PM
nickyee nickyee is offline
Constraining Height
For an upcoming study, I'd like to constrain the height of the subject while still rendering the relative y-position of the subject from thier starting point.
I understand that it would be trivial to simply not render the y-position and set the eyeheight to be constant, but is there a way to:
1) set eye-height at reset
2) subsequent y-position movement is rendered relative to this starting point
In other words, I can set a subject to be 1 meter or 2 meters tall, but if they crouch down or tip-toe, they can still get taller or shorter relative to their starting heights.
What's the easiest way of doing this?
Old 01-17-2005, 01:05 PM
tobin tobin is offline
You can apply an offset to the PPT tracking data. Look here for how to use command 7:
http://www.worldviz.com/vizhelp/VizH...er_plug-in.htm
What you'd want to do is reset your tracker, read the user's actual height, calculate the difference between his/her height and your desired virtual height, and then apply that difference as an offset.
Old 01-17-2005, 02:06 PM
Have you tried using the viz.eyeheight command? If I'm not mistaken this should do what you are wanting. For example, if you wanted to constrain the users height to 1 meter you would do:
viz.eyeheight(1)
Then to initialize the user you would issue a reset command to the tracking sensor you are using (i.e PPT):
ppt.reset()
Old 01-17-2005, 06:57 PM
I've tried both those solutions, but they both seem to be setting a base point and then adding the y-position on top of it.
So if you set viz.eyeheight(1) and I am 1.7m tall, it shows me at 2.7. And if someone is 1m tall, it will show them at 2m.
Neither seems to be able to set a height independent of the user's height.
I've tried:
if key == 'r':
headIsense.reset()
ppt.reset()
viz.eyeheight(1)
and
if key == 'r':
headIsense.reset()
ppt.reset()
selfpos = viz.get(viz.HEAD_POS)
selfy = selfpos[1]
adjust = 1.0 - selfy
ppt.command(7,"",0,adjust,0)
Am I doing something wrong?
Old 01-18-2005, 11:20 AM
Try issuing the following command after you add the ppt sensor:
ppt.command(6,'',1,1,1)
Old 01-18-2005, 02:32 PM
Cool - that worked. In case anyone else has the same problem, this is the code I used.
PHP Code:
if tracking:
headIsense viz.add('intersense.dls')
ppt viz.add('vizppt.dls')
#Average over 5 samples
ppt.command(5,'',5)
#Automatically track head position and orientation
viz.tracker()
#Add an intersense for body orientation
bodyIsense viz.add('intersense.dls')
Then for the reset button:
PHP Code:
    if key == 'r':
headIsense.reset()
ppt.reset()
        if
HEIGHT_COND == 'tall':
viz.eyeheight(HEIGHT_BASE HEIGHT_DIFF)
elif HEIGHT_COND == 'short':
Old 01-18-2005, 02:37 PM
Great, and thanks final solution.
Old 01-18-2005, 02:46 PM
Just to be clear, you only need to set the eyeheight at the beginning of the script. You don't have to keep setting it every time you reset the sensor, unless you are changing the value of the eyeheight during each reset.
