Old 06-04-2010, 06:32 AM
4711 4711 is offline
Simple Joystick Question
Hi all,
I have a question concerning the joystick buttons which is probably rather easy to be answered: How can I make my script to wait for the user to press one of the two buttons of a connected joystick.
My guess was:
import vizjoy
import viztask
joystick = vizjoy.add()
def WaitForButtonPress():
	yield viztask.waitButtonDown(None)
	print "Done."
	viz.quit()
viztask.schedule( WaitForButtonPress() )
It works fine if one replaces the "Button" by "Key" in the yield-expression, so I would have expected it to run for the joystick buttons as well. However, it does not, so what works?
Old 06-04-2010, 01:50 PM
The viztask.waitButtonDown command waits for a GUI button object to be pressed. To wait for a joystick button press in your task function you can create a custom condition. The task function in the following example waits for either buttons 1 or 2 to be pressed before it continues:
import viztask
import vizjoy
def buttonTask():
	d = viz.Data()
	waitButton1 = waitJoyButtonDown(joystick,1)
	waitButton2 = waitJoyButtonDown(joystick,2)
	yield viztask.waitAny([waitButton1,waitButton2],d)
	if d.condition is waitButton1:
		print 'button 1 was pressed'
		print 'button 2 was pressed'
	viz.quit()
class waitJoyButtonDown( viztask.Condition ):
    def __init__( self, joy, button ):
        self._joy = joy
        self._button = button
    def update( self ):
        return self._joy.isButtonDown(self._button)
viztask.schedule( buttonTask() )
Old 06-07-2010, 08:06 AM
Hi Jeff,
thanks for the clarification on the viztask.waitButtonDown command and also for your code which works fine for me!
simple VRPN question mjabon Precision Position Tracker (PPT) 2 08-25-2009 11:12 PM
simple question? Boombay Vizard 1 07-06-2009 11:51 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
Another Joystick Question Plasma Vizard 3 02-03-2004 12:16 PM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
