Old 09-08-2006, 01:25 PM
pbeeson pbeeson is offline
Collidemesh with Avatars
It seems as if the mesh that collidemesh uses for the Male and Female avatars is the default pose (with their arms outstretched). This is true even is the avatars are in another state (e.g. lady.state(1)). Is there a way to get around this? Or am I doing somehting worng: I am calling collidemesh() after I set the avatar's state.
Old 09-08-2006, 01:40 PM
Setting the state of the avatar does not immediately affect its mesh state. You must wait until the next frame is drawn to ensure the mesh has been modified to reflect the new state. So you need to wait a frame and then call collideMesh() if you want it to reflect the new state.
Old 09-08-2006, 05:53 PM
Also, be sure to remove the previous mesh VizPhysicsShape object with <VizNode>.collideNone() if you don't want the old Shape colliding with things or adding to the Avatar's mass.
Paul Elliott
WorldViz LLC
Old 09-11-2006, 02:53 PM
There is no collideNone() function.
Plus, even if I wait 10 frames, occasionally, I still run into an avatar as if its arms were outstreched even though I waited 10 frames before calling collidemesh() after setting its to state(1) (standing with arms by side).
Old 09-11-2006, 04:22 PM
Here is a little script that keeps changing the collideMesh shape of the avatar. I think this is what you want to do. Run it with the latest Vizard Beta release.
CHANGE_STATE_TIMER = 0
SET_COLLIDE_SHAPE_TIMER = 1
viz.MainView.setPosition( 0, 2, -5 )
viz.phys.enable()
g = viz.add( 'tut_ground.wrl' )
g.collidePlane()
male = viz.add( 'male.cfg' )
male.currentState = 1
male.state( male.currentState )
def onTimer(num):
	if num == CHANGE_STATE_TIMER:
		male.currentState = (male.currentState+1) % 2
		viz.starttimer( SET_COLLIDE_SHAPE_TIMER, .2, viz.FOREVER )
	elif num == SET_COLLIDE_SHAPE_TIMER:
		male.collideNone()
		male.collideMesh()
		male.disable( viz.DYNAMICS )
viz.callback(viz.TIMER_EVENT,onTimer)
viz.starttimer( CHANGE_STATE_TIMER, 3, viz.FOREVER )
ball = viz.add('ball.wrl')
g=ball.collideSphere()
def shootAhead():
	ball.reset()
	ball.translate(view.get(viz.HEAD_POS))
	vec = viz.Vector(view.get(viz.VIEW_LOOK)[:3])
	ball.setVelocity(vec*20)
vizact.onkeydown(' ',shootAhead)
Paul Elliott
WorldViz LLC
Old 09-11-2006, 04:38 PM
I'm not using version 3.0. Thus, I don't have collideNone(). Can you provide me help with version 2.5? I've switched to using collidebox instead of collide mesh for the time being to get around this problem, but I'd like a better answer.
In v 2.5, if you do the following for two avatar then later use collidingwith(), sometimes the collisions occur as if the avatars are in state #1 (correct behavior), and sometimes one or both of the avatars provide collision info as if they were still in the idle pose (arms outstreatched). Can't get this to work properly every time.
def fixmesh(avatar):
   viz.waitframe(10)
   avatar.collidemesh()
avatar=viz.add('Female.cfg')
avatar.state(1)
avatar.visible(viz.ON)
avatar.translate(x,y,theta)
viz.director(fix_mesh,avatar)
Old 09-11-2006, 08:09 PM
Let me try and address your very reasonable 3.0 concerns.
--There will be beta licenses avalable until 3.0 is released.
--Upgrading will be free.
--Vizard 3.0 is very backwards compatable. Just give your script a quick spin in 3.0. Even if your project is quite complex I doubt it would take more than an hour of work to migrate over.
Paul Elliott
WorldViz LLC
Old 09-11-2006, 09:02 PM
Any other 3.0 migration problems?
Paul Elliott
WorldViz LLC
Old 09-11-2006, 09:26 PM
It looks like viz.phys.intersectLine is faster than the old viz.intersect. But, the old intersect would ignore objects that were not visible.
1) Is there any way to tell viz.phys.intersectLine to ignore certain objects? object.disable(viz.COLLISION) doesn't seem to work, neither does turning off visibilty.
I can run viz.phys.intersectLine(begin,end,True) to get a list and then check object IDs, but I don't know if there is an easier way (especially considering that if you have many objects, it might be an optimzation to not check for intersections with particular objects at certain times). (This is also where thread 729 ended up).
2) Is there any way to get better documentation on these commands that he skeletal docs in the Vizard Help or in Python help()?
Old 09-12-2006, 10:51 AM
1) viz.phys.intersectLine() works on the physics simulation level so it only intersects with physics shapes. To have it ignore nodes, remove their VizPhysicsShape with a call to collideNone().
2) Vizard Help is the best option right now. Of course the forum is fairly good too
Paul Elliott
WorldViz LLC
