Old 12-08-2022, 09:35 AM
Debasish Nath Debasish Nath is offline
Installation of Vizard software on Raspberry PI module
Has anyone tried with running on Vizard on raspberry pi hardware module?
I have installed windows OS on a raspberry pi 4 module and had no issues in installing Vizard 6 (32 bit) in it. Even the vizard inspector program is working fine. However, the main vizard application (in which we write the code and compile) is not opening.
Any idea/suggestion regarding what might be the problem /missing for this issue?
Old 05-12-2023, 02:38 PM
mspusch mspusch is offline
Hi Debasish,
This is indeed a good question - as you can see from the Vizard folder structure, the origins of Vizard go back to it running on Silicon Graphics hardware, so in general the python based structure lends itself to run on different hardware.
That said, modern day Vizard utilizes a lot of capabilities that depend on Windows, so as of right now, the version of Vizard that is supported by Worldviz commercially only runs on Windows (or with Parallels, on a Windows emulation on a Mac).
All the best,
Matthias
raspberry pi, vizard installation
Installation of Vizard on Raspberry PI module Debasish Nath Vizard 1 05-12-2023 02:51 PM
Vizard software Installation blessonisaac Vizard 1 09-16-2010 05:02 PM
