Old 11-04-2015, 11:29 AM
sonika sonika is offline
360 panorama
Hello World Viz,
I'm new to using World Viz and Python. I would like to create a 360 panorama executable using Viz. I have the 6 cube faces images ready. But am unable to run the script.
Can someone help me with that?
Old 11-04-2015, 04:06 PM
The panorama tutorial shows how to add an environment map. Are you getting an error when you run your script?
Old 11-08-2015, 09:26 PM
I did follow the tutorials. But it does not load anything.
When I try to create an executable, it just creates a blank page. Not sure what I am doing incorrect.
Are there any references for writing the script other than that? I just simply need to use the images to create a 360 panorama executable to be used with Oculus.
Old 11-09-2015, 09:27 AM
Does it work when you run from the source file?
Old 11-09-2015, 10:49 AM
I'm using the following script.
import sys
import oculus
viz.setMultiSample(4)
viz.fov(60)
hmd = oculus.Rift()
viz.link(hmd.getSensor(), viz.MainView)
env = viz.addEnvironmentMap('beachscene.png')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
But when i run the script, all i get is a blank new window. I am not able to see the 360 panorama. Cannot create an executable. Am I missing something?
Old 11-10-2015, 11:08 AM
Any suggestion Jeff?
Running the script does not result in anything at all. Just opens another blank screen window.
I'm assuming loading the 6 cube images into a 360 panorama should be a fairly simple step as thats all I need to do. No animations or modeling involved.
Is there any reference that I should look at for the script? or can someone help me with that?
Thanks much.
Old 11-10-2015, 01:50 PM
Can you attach the environment map images here?
Old 11-12-2015, 12:01 PM
Jeff,
I have uploaded my files on WorldViz server. The reference number is 1499183.
Panorama view and binary image jai Vizard 4 11-26-2015 08:52 PM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
360 panorama walk around mshukun Vizard 1 04-24-2015 04:04 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
Page flip stereo panorama renderwiz Vizard 3 06-21-2007 10:12 AM
