Thread Tools |
Rating:
Display Modes |
I am setting up my Oculus rift DK2 with Logitech driving force GT. To use these two, I combined the two demo codes for Oculus and joy stick control (attached below). It works. But I don't feel well when I use this setup because of the very strong motion sickness. I used the position tracking from Oculus. Could anyone give me some help to improve it? reduce the motion sickness? Thanks. the code I used: hmd = oculus.Rift() # Get list of joystick device information dinput = viz.add('DirectInput.dle') devices = dinput.getJoystickDevices() joy = dinput.addJoystick(devices[selected]) joy.setDeadZone(0.05) # Check if HMD supports position tracking supportPositionTracking = hmd.getSensor().getSrcMask() & viz.LINK_POS if supportPositionTracking: # Add camera bounds model camera_bounds = hmd.addCameraBounds() camera_bounds.visible(False) # Change color of bounds to reflect whether position was tracked def CheckPositionTracked(): if hmd.getSensor().getStatus() & oculus.STATUS_POSITION_TRACKED: camera_bounds.color(viz.GREEN) else: camera_bounds.color(viz.RED) vizact.onupdate(0, CheckPositionTracked) # Setup navigation node and link to main view navigationNode = viz.addGroup() HMDviewLink = viz.link(navigationNode, viz.MainView) HMDviewLink.preMultLinkable(hmd.getSensor()) # Apply user profile eye height to view profile = hmd.getProfile() if profile: HMDviewLink.setOffset([0,profile.eyeHeight,0]) else: HMDviewLink.setOffset([0,1.8,0]) ########################### joystick turn and move speed############### joy_MOVE_SPEED = 2.0 joy_TURN_SPEED = 60.0 ################################################## ############# def UpdateView(): ########for joy control############ e = viz.elapsed() x,y,z = joy.getPosition() navigationNode.setEuler([x * joy_TURN_SPEED * e, 0, 0], viz.REL_LOCAL) navigationNode.setPosition([0, 0, (y+1) * joy_MOVE_SPEED * viz.getFrameElapsed()], viz.REL_LOCAL) ################################# vizact.ontimer(0,UpdateView) |
I would suggest looking online for best practices to reduce motion sickness in VR. Make sure you're simulation is running at 75 fps and use Direct HMD mode to reduce latency. Latency and virtual movements that don't match physical movements can cause motion sickness. You might see if gradual acceleration rather than instantaneous changes to the car speed helps. Also, see if adding a dashboard as a fixed reference in the scene helps.
Thanks, Jeff,
I tried adding a dashboard, but it helped little. I'll try your other suggestions. Thanks again. |
| Tags |
| controller, driving force, motion sickness, oculus rift |
| Oculus Rift Drift | teklab | Vizard | 20 | 04-01-2016 08:57 AM |
| Oculus Rift and 360 Panorama with Vizard Lite Edition | mshukun | Vizard | 4 | 11-10-2015 12:17 PM |
| Multiple post-process effects with oculus rift | lklab | Vizard | 2 | 03-13-2015 02:48 PM |
| Oculus Rift connection problem | mshukun | Vizard | 1 | 10-01-2014 01:15 PM |
| Oculus Rift Fullscreen | teklab | Vizard | 6 | 05-21-2014 07:11 AM |
