Old 06-13-2015, 09:04 AM
tokola tokola is offline
Change the blue line of a vizdlg/info panel
Is there a way to change the blue line used in the vizdlg panels in Vizard 5. I've tried all existing theme attributes related to color, and none of them seems to do the job. Most of them seem to be applicable only to vizmenu objects.
theme.borderColor
theme.backColor
theme.lightBackColor
theme.darkBackColor
theme.highBackColor
theme.highTextColor
theme.textColor
Old 06-15-2015, 11:01 AM
You can change the color by applying it to the border object of the panel:
panel.border.color(viz.PURPLE)
Old 06-18-2015, 09:14 AM
Thanks a lot. That works fine!
how to invoke command line question billjarrold Vizard 2 01-11-2010 09:51 AM
Draw line with a triangle at the end Chrissy2009 Vizard 9 08-24-2009 12:12 PM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 05:42 AM
