Old 04-22-2015, 01:09 PM
mshukun mshukun is offline
360 panorama walk around
Is it possible to set 360 panorama to be walking environment with Oculus rift? I used to use Oculus.setZoom to fake walking environment, but I cannot replicate the same for DK2 since the function is no longer available in Vizard 5.
Is there any alternative way to achieve the same? I have been using developed application for research (as well as introducing the developed application in research method courses) and unfortunately, the application no longer work the same after migrating to DK2 which is very problematic. I would very much appreciate if you could suggest me any solutions or resolutions with this regards.
Thank you in advance.
Old 04-24-2015, 04:04 PM
You can change the field of view using the viz.fov command.
360 panorama, dk2, oculus rift, setzoom
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Walk roobert Vizard 6 08-19-2014 07:07 PM
random walk in piazza environment maya Vizard 7 01-15-2014 04:58 AM
Export 360 panorama image with place marks mshukun Vizard 0 04-24-2013 10:20 AM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
