Old 08-23-2013, 04:57 AM
madeinjava madeinjava is offline
Question Window always on top
Hi all,
Is there any way to get my vizard window always on top?
I have an application that will run parallel with vizard's window together in the same screen. but when I click on my app button the vizard window is covered again with my main app.
This is my vizard window setup:
viz.window.setPosition(500,500)
viz.window.setSize(700,300)
viz.window.setBorder(viz.BORDER_NONE)
viz.window.setFloat()
even though in the vizard help the setFloat() function will set the window to stay on top but here in my case it does not.
Its work only when during the compiling I press the vizard logo. then I get my vizard window always on top. but I can not make it when publishing to exe since you can not press the vizard logo when you publish to EXE file.
Is there any way to get my vizard window always stay on top?
Thanks!
Old 08-23-2013, 09:09 AM
The function viz.window.setFloat() should indeed make your vizard window stay on top of other windows. You mention something about pressing the Vizard logo. I don't know what you're doing in the rest of your code, but if your code is in some kind of loop from the start, it could be that the first frame is not drawn yet, and nothing of the settings are applied. You could add this piece of code to wait for the first frame to be drawn:
import viztask
def wait():
yield None
viztask.schedule(wait())
To be sure, does this code alone also give troubles:
It works in Vizard 4, and it should work in Vizard 3 as well.
Furthermore, check the settings of the application you want to run in parallel. If both of them want to be on top, you could get issues...
Old 08-23-2013, 09:27 AM
I believe the problem is that the command is being called before the window is created ( i.e. viz.go() ). Try changing your code to the following:
This will be fixed in a future release though.
Old 08-23-2013, 09:52 AM
That was my original thought as well, although in Vizard 4 that's no problem.
Old 08-27-2013, 02:10 PM
Thumbs up
Works like a charm! Thanks farshizzo and Frank!
stay on top, window
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
[win7] Bad quality when not on primary monitor or window has no focus Huib Vizard 5 04-12-2012 06:34 AM
Using a texquad to cover a window Enlil Vizard 4 02-07-2012 03:13 PM
tkinter window focus John P Vizard 4 08-31-2009 05:51 AM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
