Old 05-29-2013, 04:19 AM
javariya javariya is offline
3d MAX models, assembling, deassembling
Hi, is it possible to manipulate the assembly of max models imported to vizard? i have seen that the inspector shows the layers and hierarchies of the model (e.g model of an engine) but when opened up in vizard it takes the whole model as a single object. I want to drag the parts away and assemble them again. Is this kind of function possible in Vizard? Thank you
Old 05-30-2013, 08:44 PM
You can get a handle to sub-parts of the object and then move them:
viz.move([0,0,-7])
lamps = dojo.getChild('wall lamps-GEODE')
moveRight = vizact.move(1,0,0,time=5)
moveLeft = vizact.move(-1,0,0,time=5)
move = vizact.sequence([moveRight,moveLeft],viz.FOREVER)
lamps.runAction(move)
Old 05-31-2013, 04:24 AM
hi, Thank you for the reply Jeff, it worked for small models i hope will work for larger as well
3d max models, assembling, deassembling
Higher Quality Models apanza Vizard 1 01-23-2012 12:21 PM
The problem of adding two .ive models hengshan.li Vizard 1 08-08-2011 01:04 AM
Self illumination of .ive 3D models flip321 Vizard 0 11-13-2010 04:28 AM
Loading OSG models and orientation Joran Vizard 4 06-18-2009 06:43 AM
executable - removing models Dave Vizard 2 05-13-2008 03:58 AM
