Old 12-08-2011, 06:04 AM
dpamplona dpamplona is offline
focal length
Hi!
I would like to control the focal length of the viewpoint.
I have found the field of view command, but I cannot find something equivalent to the focal length.
Do you know how can I do that?
Best,
Daniela
Old 12-08-2011, 04:59 PM
Can you describe the effect you are trying to achieve?
Old 12-12-2011, 07:01 AM
effect
Sure! I will try to be as clear as possible.
In normal cameras, eyes, etc, the size of the sensor is fixed and we can control manually (or automatically) the focal length. From that, the field of view of the image, is relatively easy to estimate. (If we assume the perspective tranform, then it is just the fov = 2*arctan(sensor_array_length/(2focal_length)))
In vizard, we can control easily the fov of the viewport, I would like to adjust the viewport size (in pixels) depending on the focal length. Can you help me?
Cheers,
Daniela
Old 12-12-2011, 06:53 PM
Do you want the viewport to remain rectangular?
When the viewport gets smaller are you wanting to see a black border around it?
Old 12-19-2011, 02:53 AM
problem explanation
Hi!
Thank you for your reply.
I can have the viewpoint window rectangular or squared, (that we can control with the fovH, or fovV, or h2vRatio).
I think I was not very clear with my problem.
If the "frame size"/"sensor size" is fixed in Vizard, than the focal length is easy to estimate/set with the fov.
http://en.wikipedia.org/wiki/Angle_o..._angle_of_view
For instance, it seems that openGL uses the tipical frame size:24mm x 36mm,
http://www.opengl.org/discussion_boa...&Number=193124
is Vizard also using this values?
Thank you in advance,
Old 12-20-2011, 11:02 AM
You can adjust the size of the window by using the viz.window.setSize([width,height]) command.
field of view, focal length
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
vcc avatars: defining bone length bjgold Vizard 1 08-08-2007 11:24 AM
