Old 07-27-2011, 05:16 PM
kevin kevin is offline
Timer events within a Tkinter class
Hi all,
Is it possible to have a Vizard timer event occur within a Tkinter application? I seem to be running into a problem with the Tkinter main loop dominating the program execution, so Vizard's normal functionality temporarily halts in the background. In other words, a timer event created using vizact.ontimer() will not execute within the Tkinter application. Is there a way around this?
Old 07-28-2011, 10:34 AM
Found the answer here: http://forum.worldviz.com/showthread...hlight=tkinter
Old 07-29-2011, 01:10 PM
Ran into another problem. Having Vizard embedded in the Tkinter frame works fine, and Vizard picks up mouse events. However, it does not pick up keyboard events. Here is the relevant code:
class InputSetup(Tkinter.Frame):
	def __init__(self,master=None):
		Tkinter.Frame.__init__(self,master,width=800,height=600)
		self.pack()
		viz.go(viz.EMBEDDED,window=self.winfo_id())
		viz.clearcolor(0.95,0.95,0.95)
		viz.callback(viz.MOUSEDOWN_EVENT,self.record_input)
		viz.callback(viz.KEYDOWN_EVENT,self.record_input)
		self.after(1,self.update_vizard)
	def update_vizard(self):
		viz.updateframe()
	def set_selected_variable(self,value):
		print value
	def record_input(self,e):
		self.set_selected_variable(e)
I've also tried updating Vizard's input monitoring directly using
viz.update(viz.UPDATE_INPUT)
with no luck.
Is there anything I'm overlooking that I need to manually ensure is updated?
Publishing and exe that uses Tkinter kevin Vizard 1 06-09-2011 04:02 PM
Tkinter Question mizutani_jun Vizard 0 02-24-2011 05:16 PM
Question about Vizard Expiration Timer Rate mizutani_jun Vizard 2 02-23-2011 10:13 PM
tkinter window focus John P Vizard 4 08-31-2009 06:51 AM
Timer speed Jerry Vizard 1 12-08-2006 12:01 PM
