Old 03-23-2011, 08:10 AM
blessonisaac blessonisaac is offline
Phantom omni Vs Vizard
Dear sir,
I have installed PDD driver version 3 to connect phantom omni to my desktop. Since I am using Windows XP 64 edition, version 3 driver is appropriate. But I am unable to use vizard with this version. Can you provide me a solution to use vizard software with version 3? Version 2 is not supporting to 64 edition.
I would appreciate your reply.
Thanks in advance
Blesson Isaac
Research Assistant
Praire View A M University
Old 03-23-2011, 02:08 PM
Vizard will work with the phantom and XP 64 bit. Make sure you first install the PDD drivers for 64 bit, then you install and license OpenHaptics 2.0.
Old 03-23-2011, 02:25 PM
Hi Jeff,
Thanks a lot. Now its working. Yes vizard works with phantom and xp 64 bit. After the PDD driver is installed we need to install the OpenHaptics 2.0
Blesson Isaac
Phantom, Vizard 3.0, OpenHaptics 3.0 vEsotu Vizard 2 02-02-2011 09:04 PM
SenseAble Phantom set up with Vizard jfreeman Vizard 1 06-01-2005 10:27 AM
