Old 03-17-2011, 12:11 PM
pcatalano pcatalano is offline
Clustering not working with vizcore.cfg
In Vizard 3, I was using the vizcore.cfg file to specify the settings for cluster so as to not need to start and configure the cluster master every time.
In Vizard 4, this doesn't seem to work for me. I have updated the vizcore.cfg with the changed noted in the help documents concerning cluster config options in the new version, but it doesn't help.
This is what I get. On the server side, Vizard reports:
ERROR: VizMultiCastTCP::send() failed to send data to client (WSAECONNABORTED)
On the client side, the cluster client says:
ERROR: Failed to receive initialization commands from master.
Cluster client exited with code 0
If I use the cluster master app and not the vizcore.cfg file, tho, it works fine.
Old 03-17-2011, 03:21 PM
This is a bug in Vizard 4, it will be fixed in the next beta. Thanks for reporting the issue.
Old 03-18-2011, 08:07 AM
Thumbs up
Glad to know it's not user error. Thanks!
Old 03-25-2011, 05:21 PM
A new beta has been released, which resolves this issue. Please let us know if there are any other problems.
win32ui winviz.exe has stopped working TarkaDahl Vizard 3 08-10-2010 05:19 PM
ppt 3/4 working sisun1030 Precision Position Tracker (PPT) 6 03-05-2010 09:11 AM
Tickle2 Demo not working in Vizard 3.0 mjabon Vizard 7 01-07-2008 03:59 PM
Collision with avatars and scene not working JvdBosch Vizard 12 09-14-2006 06:01 PM
Working w/ multiple scripts FlyingWren Vizard 3 10-16-2003 01:05 PM
