Old 02-04-2011, 02:10 PM
jincheker jincheker is offline
Coordinates change
Hi, I try to make some program that could add on-the-fly objects by following the path of mouse movement.
I use code like this
PointBall = viz.add('ball.wrl')
PointBall.color(viz.RED)
PointBall.setPosition(e.x , e.y,2)
where variable "e" is obtained by left-button mouse event.
I also make PivotNavigate by mouse on, but disabled left-button function part.
The problem is: when I move the mouse on the screen, those generated objects do not follow the trajectory of the mouse cursor, there are some offset.
How can I neglect this, and if I zoom in or zoom out the screen, does this method still apply?
Old 02-07-2011, 01:15 PM
Try using the <window>.screenToWorld command. Is this what you're looking for?
viz.link( viz.Mouse,viz.addTexQuad(viz.SCREEN,texture=viz.add('crosshair.png')) )
def addBall():
	ball = viz.addChild('ball.wrl',cache=viz.CACHE_CLONE)
	line = viz.MainWindow.screenToWorld(viz.mouse.getPosition())
	pos = vizmat.MoveAlongVector(line.begin,line.dir,10)
	ball.setPosition(pos)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,addBall)
viz.mouse(viz.OFF)
Old 02-08-2011, 11:01 AM
Thanks Jeff, That works
Change textbox color? renama Vizard 2 10-19-2010 07:44 PM
Change Viewpoint in different scenes lilio Vizard 1 08-28-2009 02:56 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
