Old 11-08-2010, 02:57 AM
shahramy shahramy is offline
Red face static or dynamic objects
Hi every body
is there any way to create static or dynamic Objects?
static objects are such as ground or trees or any fixed Objects and dynamic objects are ones which can interact with environment like a car which can move or an avatar
MSc Shahram Shahraki
Old 11-08-2010, 10:16 AM
You can add actions to objects to animate them. Take a look at the Vizard help for documentation and examples about adding actions to objects and using the avatars included with Vizard.
If you are asking about creating the models, then that is done in modeling software. Our supported workflow for that is through 3ds Max.
Old 11-10-2010, 01:32 AM
Red face
thank jeff but I meant is there any difference between static and dynamic object? does vizard differentiate these two type of object, between objects which are fixed and others which may move?
multiple objects durf Vizard 1 04-10-2009 02:42 PM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 01:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
