Old 02-22-2005, 02:38 AM
exhale exhale is offline
Text unreadable
i'm evaluating this software because we
might use it in a psychology related
VR project.
Now as i was watching the demo's,
it seemed al text that is used to
display some info in the 3d world is
unreadable, if needed i'll supply a
screenshot.
how can i resolve this issue?
greets,
Kevin
Old 02-22-2005, 08:25 AM
tobin tobin is offline
Do you know if you're running on ATI graphic hardware? Such hardware unfortuantley can cause text problems under some versions of Vizard. Which demo and which version of Vizard are you experiencing this?
If you don't know what you're graphics hardware is or if you know it's not ATI, then we would certainly appreciate it if you sent us a screenshot for further evaluation.
Thanks.
Old 02-22-2005, 09:08 AM
Thank you for the reply.
Indeed this system is using an Ati Rage chip 32 mb. I'm using the latest trial edition, which i download this morning.
Is this glitch on all Ati chips or only on the older rage boards?
By the way this happens with al
examples which are included with the trial.
is there a work-around?
Because we might use this system
to develop, but the final system which
will run the VR simulation, will use a
Nvidia Quadro FX 3400, that shouldn't
be a problem right?
I sure hope there is a workaround.
Is the same function used for text to create a 2D visual interface in the VR-app with your software?
thanks in advance,
greets,
Kevin
Old 02-22-2005, 12:31 PM
First, could you please verify that you're running 2.50 or later of Vizard. Starting with those releases some texture/text handling problems on ATI hardware have been resolved. There are no known issues with nVidia hardware and we currently consider nVidia our baseline for performance.
Our ATI tests are done on Radeon hardware using the latest Catalyst drivers. Could you please verify your Catalyst drivers are the most recent, and if so, then can you try on a different ATI chipset?
Old 02-23-2005, 02:09 AM
I verified the vizard version: 2.50b
Next, i installed the latest drivers. note
this is a dell machine and the regular
ATi-website drivers did not work. But
the date of the drivers of the dell website seemed to match the ati
drivers published on their website (well almost, that is).
This is an older Ati Rage 128 Ultra chipset. Unfortunately this card does not use the catalyst driver set.
Other sys specs: P4 2.4 512mb on Windows 2000 etc.
(Dell precision 340)
Another problem i'm running into is
complete system locks on running the
3D demo's. (ctrl-alt-delete, alt-f4, alt-tab = no response, no more mouse-movement either). This first
happened with the "mini"-cardemo,
and just a few minutes ago also on other demo's, this time i ran collision demo to check the font problem,
and as i dragged the 3d window i
got the lockup.
At the moment i can not test another
Ati-board @ work. I could at home
though on an x800 card, but as u know
i will be developing @ work, so that's
no solution. I'll check if i can get a hold
of another card here.
Do you have any other suggestions,
regarding the system lock-ups and
unreadable text?
(system is up-to-date as far as possible, and has anti-vir mcaffee etc)
thanks in advance,
greets,
Kevin
Old 04-03-2014, 04:23 PM
rlh001 rlh001 is offline
I have a intel HD graphics 4000. when I try to display text some of the letters are dim . Oddly this only happens when I update the graphics with a timer.
Has any one seen this? Thanks
Old 04-04-2014, 01:04 AM
Is it screen text or world text and can you post the code you are using? If the text placed in the world and depends on the angle you are viewing from try the following:
text.disable(viz.LIGHTING)
Old 04-04-2014, 05:28 AM
Depending on the TEXT used different letters will be dim .. Here they are only dim in non full screen. other times they are missing and dim on full screen.
trackDisp = viz.addText('First message on screen',parent=viz.SCREEN, )
trackDisp.message('second message from in line code')
TimerID = 1
#Create a function to handle the timer events.
def onTimer(num):
# #Use the time ids to identify the timer.
print 'timeout'
trackDisp.message('this is the text from the timer 123456789')
#Register the timer callback.
viz.callback(viz.TIMER_EVENT,onTimer)
#Start timer.
viz.starttimer( TimerID, 1, viz.PERPETUAL )
Old 04-08-2014, 08:23 AM
It could be an issue with a certain version of drivers. If you haven't yet, try updating the drivers for your Intel 4000. Or roll back to an older version.
Old 04-09-2014, 05:52 AM
I just updated to the latest driver and unfortunately the problem persists
Old 04-09-2014, 10:51 PM
Do you have the same problem with text if you run the PigeonHunt demo? That uses text for a countdown timer.
Old 04-10-2014, 05:41 AM
When I change to viz.ORTHO like Pigeon Hunt it works. Does not work with parent= viz.SCREEN
trackDisp = viz.addText('First message on screen',parent=viz.ORTHO ,fontSize=20)
