Old 08-02-2010, 10:52 AM
malmct malmct is offline
Tkinter interface
I'm building a program based around a tkinter interface, which is supposed to start vizard rolling. However, when I try and do this, vizard gets caught at the loading screen and the splash animation plays endlessly. How do I fix this?
Old 08-02-2010, 03:10 PM
The following example shows how to embed the Vizard graphics window into a TKinter application:
from Tkinter import *
class VizardApp(Frame):
	def __init__(self, master=None):
		Frame.__init__(self, master,width=800, height=600)
		self.pack()
		#Embed vizard using the viz.EMBEDDED flag and passing handle to existing window
		viz.go(viz.EMBEDDED,window=self.winfo_id())
		#Initialize Vizard environment
		viz.add('tut_ground.wrl')
		ball = viz.add('ball.wrl',pos=(0,1.8,2))
		ball.add(vizact.spin(0,1,0,90))
		#Need to setup timer to manually update vizard engine
		self.after(10,self.updateVizard)
	def updateVizard(self):
		"""Update the vizard engine"""
		viz.updateframe()
# create the application
myapp = VizardApp()
# set title of application
myapp.master.title("Vizard Tkinter example")
# start the program
myapp.mainloop()
tkinter window focus John P Vizard 4 08-31-2009 06:51 AM
viz.Screen Images overlap and Interface Button jaylocco Vizard 1 08-28-2009 04:18 PM
how to write the interface code nasr Vizard 17 05-19-2009 05:21 AM
3D Music Interface Psirus Vizard 3 02-26-2008 12:48 PM
tkinter setup for 3.0 jrodman Vizard 2 11-16-2006 03:50 PM
