Old 02-15-2010, 12:15 AM
Veronika Veronika is offline
size of avatar
how find I size of avatar, which I loaded using the command:
avatar=viz.add('male.cfg')
I mind its size, height, etc.
Old 02-18-2010, 12:27 PM
You can get the bounding box of an object and look at its dimensions.
male = viz.add('male.cfg')
box = male.getBoundingBox()
print box.size
#show bounding box on avatar
male.add('box.wrl',alpha=.2,pos=[0,box.height/2,0.05],scale=box.size)
#Setup camera navigation
import vizcam
vizcam.PivotNavigate(center=[0,1,0],distance=5)
Old 07-30-2014, 05:12 AM
johnallen johnallen is offline
Thanks, that was helpful.
Can this be found using Inspector at all? That would be the perfect place for it.
Old 07-30-2014, 02:29 PM
Yes, if you click on an object in Inspector it will display the bounding box. You can see the bounding box dimensions in the status bar at the bottom of the window.
Avatar - size of the bones rfam Vizard 1 01-26-2009 11:34 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
size of anacapa avatar alaa Vizard 0 04-25-2005 01:21 PM
