Old 01-02-2010, 08:19 AM
shahramy shahramy is offline
Unhappy minicooper
hi every body. i have used mini cooper in my project and move it. but i can`t spin the wheels. please help me how can i do it?
Old 01-05-2010, 05:39 PM
You can do this but you'll need to use an undocumented Vizard plugin called SceneGraphTools.dle. Here is an example that spins the right front wheel.
osg = viz.add('SceneGraphTools.dle')
car = viz.add('mini.osg', pos = [0,0,7], euler = [90,0,0])
# Get raw handle to 'rfr' group node
rfr = osg.getRootNode(car).findChildren('rfr')[0]
# Get handle to children
children = rfr.getChildren()
# Create new raw group node to hold children
tireGroup = osg.addGroup('RightFrontTire')
tireGroup.setChildren(children)
# Insert tire group underneath rfr node
rfr.setChildren([tireGroup])
# Get handle to new group node
tire = car.getChild('RightFrontTire')
spin = vizact.spin(1,0,0,90)
tire.addAction(spin)
Old 01-14-2010, 12:58 AM
thankyou. but how can I get this undocumented Vizard plugin?
Old 01-14-2010, 01:23 PM
The plug-in is included with the Vizard install. Just make sure your version of Vizard is up to date and you should be able to run that script. You can check that by going to Help --> Check for Updates.
Old 01-23-2010, 01:30 PM
thanx a lot
